Hi.
Im running a 3700x with an msi b450m gaming plus.
Msi has these leds on the mobo that light up when something gles wrong. The cpu led lights up and it wont boot. This pc has been running fine yesterday. It randomly does this once a week for the last two to three weeks. I remove and insert the cpu in the socket. This time that didnt help either. I dont know what do now.
Does anyone have a clue?
https://linustechtips.com/topic/1111486-cpu-led/
Some MSI motherboards have a bad habit of letting up the CPU LED error light when actually the ram is at fault. What happens when you run with XMP off for a while?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1111486-cpu-led/#findComment-12948791
Hmm id like to try that. But i cant turn off xmp without getting in the bios,or is there any way to do it without getting in the bios?
https://linustechtips.com/topic/1111486-cpu-led/#findComment-12948795
Ive got some ramsticks laying around here. Should i try with these?
https://linustechtips.com/topic/1111486-cpu-led/#findComment-12948800
Ok so likely not the ram.
Disconnect all non-critical things including USB devices. See if it boots at all.
If not, move the GPU to another slot. If you have a spare gfx card, useit instead if moving old gpu to different slot doesn't work..
Edit: if above doesn't work then try that 2600x.
-アパゾ
https://linustechtips.com/topic/1111486-cpu-led/#findComment-12948866
If not, move the GPU to another slot. If you have a spare gfx card, useit instead.
I only had power connected the whole time  nothing else. Il try different gfx cause i only got one slot
https://linustechtips.com/topic/1111486-cpu-led/#findComment-12948871
Could it be a loose cable from the psu side?
https://linustechtips.com/topic/1111486-cpu-led/#findComment-12948875
did you overclock the cpu or ram in bios?
  • CPU
    AMD Ryzen™ 7 5800X 4.7Ghz
  • Motherboard
    MSI MEG X570 ACE
  • RAM
    G.SKILL Trident Z Royal Series 32GB (2 x 16GB) F4-3200C16D-32GTRS
  • GPU
    GeForce RTX™ 3060 EAGLE OC 12G (rev. 2.0)
  • Case
    Cooler Master MASTERBOX MB520 ARGB + Cooler Master MasterFan MF120R ARGB
  • Storage
    ADATA XPG SX8100 2TB PCIe Gen3x4 M.2 2280 SSD
    ADATA LEGEND 960 4TB PCIe Gen4x4 M.2 2280 SSD
    ADATA Ultimate SU800 2TB 2.5" SSD
    Crucial BX500 2TB 3D NAND SATA 2.5-inch SSD
    Toshiba X300 4TB 7200 RPM
    TOSHIBA MG06 (MG06ACA10TE) 10TB 3.5 Inch 7200RPM Enterprise SATA Hard Drive
  • PSU
    Cooler Master MWE GOLD 750 FULL MODULAR
  • Display(s)
    Acer KG271B Gaming Monitor (HDR Ready 27" 1920X1080 240Hz)
    MSI PRO MP241
  • Cooling
    Cooler Master MASTERLIQUID ML240R RGB
  • Keyboard
    MSI Vigor GK80 RED GAMING KEYBOARD
  • Mouse
    Razer Naga Hex Wraith Red Edition Wired Laser Mouse
  • Operating System
    Windows 11 Home
  • Router
    tp-link EB810v BE22000 Tri-Band Wi-Fi 7 VoIP Router
    Asus ROG Rapture GT-AX 11000
  • Network Card
    tp-link Archer TBE550E BE9300 Wi-Fi 7 Bluetooth 5.4 PCIe Adapter
https://linustechtips.com/topic/1111486-cpu-led/#findComment-12948909
13 minutes ago, APasz said:
Could be.
2600x booted. But now the vga led turns on. Usually turns off after few reboots. So i guess 3700x has issues. But msi command center runs the 3700x as 4.25ghz stock. Could that be the reason? If so how do i reset the clocks without booting up cause i cant boot with 3700x :D
edit. Vga turned on cause theres no gpu installed i think. Lemme get that gpu in
https://linustechtips.com/topic/1111486-cpu-led/#findComment-12948944
@_@...you can try resetting the cmos...if your motherboard doesn't have the cmos reset button you can remove the cmos battery wait awhile and put it back...
  • CPU
  • Motherboard
    MSI MEG X570 ACE
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    MSI PRO MP241
  • Cooling
  • Keyboard
  • Mouse
  • Operating System
    Windows 11 Home
  • Router
  • Network Card
https://linustechtips.com/topic/1111486-cpu-led/#findComment-12948950
wait...is the motherboard's bios updated?
  • CPU
  • Motherboard
    MSI MEG X570 ACE
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    MSI PRO MP241
  • Cooling
  • Keyboard
  • Mouse
  • Operating System
    Windows 11 Home
  • Router
  • Network Card
https://linustechtips.com/topic/1111486-cpu-led/#findComment-12948971
since it works perfectly with 2600x...i'm thinking that you did not update the bios  for ryzen 3000s...
  • CPU
  • Motherboard
    MSI MEG X570 ACE
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    MSI PRO MP241
  • Cooling
  • Keyboard
  • Mouse
  • Operating System
    Windows 11 Home
  • Router
  • Network Card
https://linustechtips.com/topic/1111486-cpu-led/#findComment-12948973
