hey guys Im really really hoping some one can help me out iv looked everywhere online no one seems to be having the same problems as i em..
issue i have. i have 5 Corsair hd fans 4 140mil fans and 1 120mil fan randomly my lighting stoped working on all the fans and as i was disecting the problem i can get one fan to work only one fan at a time when i plug the led hedder into the corsair led hub into slot 1 all the other fans will not work when i plug them into hedder 2 3 and 4 now i tried the led hedder into the led header 1  and so all the fans will work by them self but only one at a time connected to led header 1.... they dont work in sync iv had the led hub replaced and its doing the same thing... ps i have the commander pro also with the led hub connected to the commander pro taking the commander pro out of the hole thing also same problem....
https://linustechtips.com/topic/1110954-corsair-commander-pro-help/
Have you tried restarting your PC.
Join HWBot or OCN
#1 3DM Fire Strike Ultra score in the world.
#2 3DM Time Spy Extreme score in the world.
#3 3DM Fire Strike Extreme score in the world.
#7 3DM Sky Diver score in the world.
#8 3DM Fire Strike score in the world.
#12 3DM Time Spy score in the world.
All scores obtained with 8600K + 1x 1070Ti. Links in bio
Wish I could help you but I cannot replicate the problem, nor have I encountered it. Whenever my Commander Pro freaks out I just restart and it fixes itself.
Do you have a 3rd party monitoring program running like HWinfo or something of the sort?
Is the commander pro updated fully?
Join HWBot or OCN
This may sound stupid, but have you checked under the Lighting Setup for the Commander Pro to make sure that it still knows that you have 6 fans?  If the software only thinks that you have one fan, that might be why only one fan at a time lights up.  Maybe something screwy happened and the Setup settings were changed somehow.
Only other thing that I can think of would be like @Fakmykak said and that there is some other monitoring program running.  I know that my Commander Pro does weird things if I run HWiNFO64 and let it take over sensor monitoring.  Plus, if I run Ryzen Master and reboot the system after making changes and it first reboots with Ryzen Master opening, then iCUE will not recognize any device hooked up to it until I restart again.
You can contact Corsair support. Maybe they have some troubleshooting solutions. Expect them to take a month to reply to your Email though.
Join HWBot or OCN
I had the same problem with them taking ages to reply to mails!
Pro tip: use messenger to contact their Facebook account! At least for their German account they usually respond at least the next day, if not within hours.
Sounds stupid, but works ^^
My Rig / Buildlogs:  ❄️ SNOWFLAKE ❄️ FROSTBITE ❄️
CPU: Ryzen 5 3600   Cooler: Corsair H115i Platinum   RAM: Corsair Vengence RGB Pro 16GB @3200   Mobo: Asus Prime X470 Pro
Graphics Card: Gigabyte Aorus 2080super Waterforce    Case: Corsair 500D   PSU: Corsair HX850i
Storage: 500GB Crucial P1 NVMe SSD, 1TB Crucial P1 NVMe SSD, 2x 1TB SATA SSD
Displays: AOC CQ32G1 32" 2560x1440, Acer XB280HK 28.0" 3840x2160 60 Hz, Medion MD20850 24" 2560x1440
