I was so nervous putting my wraith cooler on and the clips would not clip so i was kinda sliding the cpu cooler and now im kind of panicking because is it possible to over smudge the thermal paste. should i take it off and go buy thermal paste and remove the one i smudged.
i was not thinking it was not lining up so i pushed it to the right a bit so the clip would go over and did that a few times. I could be over thinking this i am just fucking so nervous, this is only my second pc build.
https://linustechtips.com/topic/1110449-help-me/
basically, if you aren't pulling a verge pc build guide and dumping thermal paste on it, you're fine
Don't forget to use the "Quote" feature or mention me ( @Gegger) if you want me to see your reply!
Community Standards // Forum Quickstart Guide // Floatplane // Forum FAQ // The Parrot Gang
Banned by Linus in the "banning game" thread who added insult to injury by putting this crap in my sig >(
WE ARE THE DARK SIDE Don't be a light theme peasant
             ........:oo:........
           o//ssssssssyhhysssss+////o               .''''''''''''''.
          mddmmm/::ddddddddddddddmmmyss::/mmN       |   PARTY ON   |
          o..+oodddmmmhhhhhhhhhhhdmmmmmdddooy       | ,............'
         h::oyyhddmmm+++///////////++++++mmmddy::s  |/
      Nyyo[[sddhyyyyy::::::::::::::::::::yyymmh//oyym
     h..:oohmm+:://///::::////////////////+mmmmms..sNN
     m++sddmmm+::hddhhy::+ddddddddddddddhhhmmmmmdhh+++d
    Nsssyyhmmhssooodmmhhh::+mmdyyyyyyyyddddddmmmmmmmmo::d
   mmd../mmmmmo::shhdmmhhh::+mmhooooooooyhhmmmmmmmmmmmyssdmm
  +++++smmdddo::///dmmhhh::+mmhooooooooooommmmmddddmmmdd/++m
 ``+hhhmmhoo/:::::oooooossymmhooooooooyyymmdoooooydddmmo//N
 ++:mmmmmy:::::::::::::/yyhmmhooooooooyhhmmd:::::+yyhmmyssddd
ooommmmmy:::::::::::::://ommhooooooooooommd:::::://shhdmm+..
yyhmmh++/::::::::::::::::+mmhooooooooyyymmd::::::::/++hmm+//
dddmmh++/::::::::::::::::+mmhooooooooyhhddh:::::::::::hmmysshhd
mmmmmdhhs::::::::::::::::+mmhoooooooohhhhhy:::::::::::hmmhhh``+
mmmmmh++/::::::::::::::::+mmdhhsooooodmm++/:::::::::::hmmsss``+
dddmmhoo+::::::::::::::::+dddddyssyyydmm::::::::::::::hmmsoo++o
dddmmdhho::::::::::::::::+hhdmmddddmmmmm::::::::::::::hmmsooNNN
mmmmmh///::::::::::::::::+hhdmmmmmmmmddd::::::::::::::hmmsoo++/
yyhmmdss+::::::::::::::::/ooydddmmmmmsoo::::::::::::::yddhyy::+
++ommmmmy:::::::::::::::::::ohhdmmddd/::::::::::::::::shhdmmsssNNNmmN
..+mmmmmy:::::::::::::::::::://shh+//:::::::::::::::::://dmmmmdoo+..o
``+dddmmhss+:::::::::::::::::::+++/::::::::::::::::::::::ooodddhhysshNNy++m ``+hhdmmdhhs///:::::::::::::::::::::::::::::::::::::::::::::yyymmmmmmmmo++hNNmdd ``+hhdmmdhhhhh+:::::::::::::::::::::::::::::::::::::::::::::::/hhhhhdmmmmmsoo... ``+ddmmmdhhhhhyyyyyyyyyyyo:::::::::::::::::::::::::::::::::::::+++++sdddmmdhhsss//+ ``+mmmmmhsshhhhhhhhhhhhhhy++/:::::::::::::::::::::::::::::::::::::::+ssyyydmmddd///hhd ``+mmmmmy::shhhhhhhhhhhhhhhhs:::::::::::::::::::::::::::::::::::::::::::::ymmmmmmmh../ ``+mmmmmy:://////////////ohhhyy+::::::::::::::::::::::::::::::::::::::::::///hddmmmhhs++s ``+mmmmmhssssssssssssssssydddddysssssssssssssssssssssssssssssssssssssssssssssdddmmmmmy::s ``+mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmhooh
https://linustechtips.com/topic/1110449-help-me/#findComment-12940321
smudged thermal paste aint so bad. did you check temps while running it?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1110449-help-me/#findComment-12940327
Just now, JB25304 said:
I had a pesky time getting that thing on as well.  I just removed it to put on my CPU water block last weekend.  The paste was where it needed to be and nowhere else, so as long you were not sliding it extremely off the processor, it should be fine.
yea i dont see it leaking from the side so i thought i was ok but i had a panic attack for a second. i didnt want to destroy my pc i got today lol.
https://linustechtips.com/topic/1110449-help-me/#findComment-12940329
I totally understand that lol.  Like @Fasauceome said above, check your temps while running it.  If something seems off, you can always take it off and reapply, but I would bet that you are just fine.
https://linustechtips.com/topic/1110449-help-me/#findComment-12940339
That would be pretty hard to do
at worst your temps might be a bit high if it got some air gaps, but as long as it's running fine whatever
https://linustechtips.com/topic/1110449-help-me/#findComment-12940342
