After 3 hours of work my first build is complete! The cable management is not the best due to non modular psu.
Heres the juice
  • CPU
    AMD Ryzen 5 2600x 3.4 GHz 6-Core Processor
  • Motherboard
    Gigabyte B450 AORUS M Micro ATX AM4 Motherboard
  • RAM
    Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory
  • GPU
    Gigabyte GeForce GTX 1660 6 GB GAMING OC Video Card
  • Case
    Thermaltake Versa H18 MicroATX Mini Tower Case
  • Storage
    Crucial MX500 500 GB 2.5" Solid State Drive
  • PSU
    Corsair VS 550 W 80+ Certified ATX Power Supply
  • Cooling
    Deepcool Gamerstorm Captain 240 PRO
  • Operating System
    WIndows 10 home
https://linustechtips.com/topic/1110097-thermaltake-first-build/
Wow those pictures came out horrid lol. I have bad lighting when i took them.
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Cooling
  • Operating System
    WIndows 10 home
hate to instill buyer's remorse but that's not a good power supply choice for your hardware. Not fire hazard level but consider upgrading it when you are getting a new GPU or something.
Primary PC:
PSU tier list
How many watts do I need?
I dont think i will upgrade for a while. I will keep this in mind. Thank you!
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Cooling
  • Operating System
    WIndows 10 home
I love thermaltake, and this is my favourite budget case of theirs right now, front airflow is great, built in it myself, great choice in my opinion.
Also don't beat yourself up over cable management, the front looks pretty much as good as you can get, for the back you 'could' move the CPU 8 pin to the right side and tuck it in along that side of the frame, but don't, you've done a good enough job.
Also I disagree with the above, I can't find any reviews of it specifically, but it's corsair, it has over 500W on the 12V rail, good warranty, don't worry about it, it's not a no name, non-80+, you'll be fine.
1660 is also the smart Nvidia GPU at the price point instead of the 1650 or 1660ti, just overclock it, 2600, love that thing great cpu will last you ages.
Yeah it's a great budget build, well done!
Thank you!
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Cooling
  • Operating System
    WIndows 10 home
