Like, are they almost fully inserted or not even close?
Please check again if you have the notch at the correct location.
 maybe close one of the clamps, then install the dimm at an angle and press it into the second clamp.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1110084-someone-please-help/#findComment-12936963
yes they are almost fully inserted
potato.
https://linustechtips.com/topic/1110084-someone-please-help/#findComment-12936975
they are like a mm away from fully
potato.
https://linustechtips.com/topic/1110084-someone-please-help/#findComment-12936977
4 hours ago, TensorVortex said:
well
it need to be fuly inserted, and you will hear a click.
open both clamp, look check all pins are good
put ram back in
push with both hand, make sure mobo is not flexing bending.
btw guys thanks for the help i managed to make it work
potato.
https://linustechtips.com/topic/1110084-someone-please-help/#findComment-12937547
