Best way to go about cleaning cooler?
ImAyaanKhan
I have a cooler master hyper 212 evo rgb black edition and there are a few stains on it, so I removed it and I need to know the best way to clean the stains off, as they are on the fins and not the pipes. Would it be safe to wash it and let it dry for a day, or is there a better method?
Current PC (Second Build) : CPU: Ryzen 5 1600 (OC @3.8GHz, sometimes pushed to 4GHz) RAM: 16gb Corsair Vengeance RGB Pro DDR4-2666 (OC @2733Mhz, sometimes pushed to 2800 for testing purposes)   GPU: PowerColor Radeon RX570 8gb MOBO: ASRock B450m Pro4 SSD: Inland 120gb HDD: 1tb Seagate Barracuda PSU: Cooler Master Masterwatt 500w Lite Case: NZXT H500 OS: Arch Linux+ KDE Plasma [Desktop Environment] & Windows 10 Pro [Broken due to grub 50% of the time]
Accessories: Mouse: Alienware AW958 Elite Keyboard: Corsair K63 Wireless  Headphones: Samsung Level On Pro
Phone (waiting on arrival): Samsung Galaxy Note 9
water and soap
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
Just now, Constantin said:
water and soap
Alright, Thanks!
21 minutes ago, Augustin said:
scrape the hardcore dust build up with a credit card/plastic
Ehh, I've already washed it and it sounds like using a credit card could scratch it
plastic won't scratch metal
