Problem with Intel Hd Grapics
Go to solution Solved by bloodsnapper,
It worked thanks
Quickest way would be to open Device Manager and look under 'Display Adaptors' for 'Intel UHD graphics 630'.
If it's there then you have a 9900K and the iGPU is enabled.
If not;
When booting up press either F2, F8, F10, F11, F12, or Del depending on your mobo, to get into the BIOS.
Once in, look through the menus for an option called "Enable iGPU" or "Use integrated GPU" or something along those lines.
-アパゾ
