I have a problem with my RAM. Normally, it runs at 3200MHz, but sometimes, it runs at 2666MHz. There are no BIOS and hardware changes at all. Anyone facing the same issues?
Specs:
AMD Ryzen 3600
RAM: AData XPG 3200MHz RGB
MoBo: Gigabyte Aorus X570 Pro WiFi
I have ASD (Autism Spectrum Disorder). More info: https://en.wikipedia.org/wiki/Autism_spectrum
I apologies if my comments or post offends you in any way, or if my rage got a little too far. I'll try my best to make my post as non-offensive as much as possible.
https://linustechtips.com/topic/1107308-problem-with-memory/
11 minutes ago, PMKNMSTRBILLJ88 said:
id check to make sure you dont have a dead or dying ram stick.
what config are you running? 1 stick or 2 and what capacity
I have 2 sticks of RAM, each 8GB, and they are identical, bought at the same time.
I also inserted at the slots the motherboard manual recommended, which is A2 and B2 slots.
https://linustechtips.com/topic/1107308-problem-with-memory/#findComment-12915206
4 minutes ago, PMKNMSTRBILLJ88 said:
try the A1 B1 slots. or do you have any other ram there to test?
Hmm, Okay. I don't have any extra RAM to try out. I'll try switching slots.
Anyway, the RAM speed sometimes just go down to 2666MHz even with XMP profile activated. I have to go to BIOS, play with the XMP profile, then restart, and the RAM boost to 3200MHz.
https://linustechtips.com/topic/1107308-problem-with-memory/#findComment-12915233
