Should I buy parts or pre-built
I am going to buy a new computer and I have looked into building one myself or buying a pre-built one. I don't know much about parts but my budget is 2500, and I am trying to get both an i9-9900k and a 2080 ti. I also played around with the cyber power configuration, but I don't know much about it.
In short, my question is what computer I should buy to get maximum gaming performance with 2500 dollars.
Links to computers I have looked at:
https://pcpartpicker.com/guide/8B6MnQ/glorious-intel-gamingstreaming-build
I wasn't able to make a link but here is the name - Cyberpower: Gamer Infinity RX Ultra 300 Gaming PC
generally, building instead of buying prebuilt lets you know every last part that's in your PC, and better bang for buck since you don't pay for the construction.
plus or minus a windows license, if you're into that
Primary PC:
Thanks for the fast response. I was wondering if it would be worth to wait for the new Ryzen 9 3950X and also what the difference is between i9-9900k and the Ryzen 9 3900x.
I am looking to buy an Alienware ah2518hf monitor and I want to be able to reach 240 fps with my computer. Is Freesync or G-sync better for gaming?
I will also be looking into overclocking,
