BASH/PS/DOS syntax highlighting for code blocks
It would be useful to have BASH, PowerShell and maybe DOS syntax highlighting in code blocks; shell commands are definitely more used on the forum than LaTeX or SQL.
Don't ask to ask, just ask... please聽馃え
sudo chmod -R 000 /*
It makes sense, but I'm not sure how straight forward it is for me to add languages (as opposed to IPS). I believe all three of those are supported by the code editor and the syntax highlighting library, but I don't know how easy it would be for me to turn it on. I will look into it.
HTTP/2 203
I've had a look and unfortunately I don't think it's going to be possible to add new languages. The languages that are displayed are the only ones that have been packaged in our distribution of the code editor, and it's not something that can be easily swapped out with a different version by me.
HTTP/2 203
