Exchanging PSU power cables
Solved by TheGlenlivet,
6 minutes ago, Saturn420 said:Ive had to install a new PSU as my old one started having issues, but the power cable that came with the new one isnt long enough to reach my nearest socket. The old PSU is the same wattage and brand (evga 500w) and i was wondering if i could simply use the old cable instead of having to move my pc
thanks
When you say power cable you mean the one from the wall to the PSU?
Then yes for sure.
