I have a WD My passport External hard drive. I faced a small issue . Whenever I connect it to my PC through a USB 2.0 port, it is recognized , whereas if I connect it through a USB 3.0 port , it is not recognized. What may be the possible reason for this problem and what should I do to get it resolved ?
https://linustechtips.com/topic/1105216-external-hard-drive-not-recognized/
That is really weird. Maybe something with your USB ports? Maybe even a drive is bad on them?
Do you have another computer you can try it on? If it works on other machines, then it is something with your USB ports on your computer.
Be sure to @Pickles von Brine if you want me to see your reply!
Stopping by to praise the all mighty jar Lord pickles... * drinks from a chalice of holy pickle juice and tossed dill over shoulder* ~ @WarDance
3600x | NH-D15 Chromax Black | 32GB 3200MHz | ASUS KO RTX 3070 UnderVolted and UnderClocked | Gigabyte Aorus Elite AX X570S | Seasonic X760w | Phanteks Evolv X | 500GB WD_Black SN750 x2 | Sandisk Skyhawk 3.84TB SSD
