1 minute ago, Firewrath9 said:
doesn't look too bad, japanese main caps, 5y warranty, and from reviews the vreg and ripple isn't too bad.
You sure you're not looking at the Smart Pro? Cause his in the lowest possible tier with the rest of the industry's garbage
https://linustechtips.com/topic/1105036-smart-bx1-rgb-550w/#findComment-12897097
Smart =/= BX1, the smart is an older design that is group-regulated, and is 80+ white, the Smart BX1 is a newer one.
https://linustechtips.com/topic/1105036-smart-bx1-rgb-550w/#findComment-12897101
Smart also comes in 80+ Bronze and is indeed also group-regulated junk with pretty poor performance and shoddy soldering.
https://linustechtips.com/topic/1105036-smart-bx1-rgb-550w/#findComment-12897104
10 hours ago, WDeveloper said:
Hi,
Please, I need your input regarding this PSU, it seems the only option under my budget:
https://www.thermaltake.com/smart-bx1-rgb-550w.html
Thanks,
Better get a good PSU from Seasonic or Corsair just to be in the safe side.
10 hours ago, 5x5 said:
It's a good ballistic missile warhead. Not a great power supply, though
not a ballistic missile but a smaller ticking time bomb xD.
https://linustechtips.com/topic/1105036-smart-bx1-rgb-550w/#findComment-12897829
