20 minutes ago, Hunter115 said:
my pc freeze occasionally when i game and only is responsive again when i reboot. i dont know what the problem could because i checked the cooling and the gpu. And i have no way of checking the cpu ram and motherboard
Why don't you go to your BIOS and check temps.  Both it won't be on load.  Run Aida64 the if getting freezing try one stick of ram and let us know.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1104531-freezing-problem/#findComment-12892833
What looks your ram usage like while gaming ? Maybe you just run out of it !
Is your 8 gb in dual channel ? Maybe its just memory leak !?
I had freezes and stuff lile that in games like rust where 8 gb is just not enough !
If you have no way of upgrading at least maybe try a big pagefile on multiple drives to help the ram out.
Another thing that  feelt like that to me was faulty audio drivers ( sonic suite) some realtek drivers aswell !
https://linustechtips.com/topic/1104531-freezing-problem/#findComment-12892896
