Can I buy a 50$ PSU with no additional 4 Pin for the CPU or do I need to invest more to provide the cable (8 Pin + 4 Pin) and be save that everything works?
some say its only for extreme overcloking
some say its required --> doesn't work without
What is right? What PSU can you recommend for Ryzen 5 3600+5700XT+16GB RAM?
https://linustechtips.com/topic/1104407-4-pin-cpu-connector-required-help/
8 pin is required
4 pin is supplemental and only needed for extreme overclocking
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
For the love of God don't buy a $50 PSU for that build. Think of it this way, the PSU is quite literally directly connected to almost every component in your PC and if it fails it has the potential to dump the input voltage (220v, 240v or 120v depending on where you live) directly into the output rails (12v, 5v, -5v and -12v). As you can imagine dumping 120v into a 12v component is bad, very bad.
Buy a rated PSU, at least then you can be sure it has protection from killing other components with itself if it dies.
Never skimp out on the PSU.
Main Rig:-
Server:-
Buy a rated PSU, at least then you can be sure it has protection from killing other components with itself.
Thanks! I will keep that mind and bye a better one. You have a similar setup as what I plan to do. Is your CPU with both ( 8 Pin and 4 Pin) connected? Or only with 8 Pin?
5 minutes ago, Jakob22122003 said:
So if I overclock my CPU it won't damage the PCB?
You'll kill the CPU long before you damage the PCB of the motherboard and either of those scenarios are very unlikely unless you're doing something like 1.5v or something stupid high like that and disable all protections on the motherboard to shutdown and protect itself.
Prior Build Log/PC:
Ok! So I will be fine without 4 Pin? I will do overclocking very gently. ?
Yes, just to put you at ease, I was able to overclock a 7900X on just the 8-pin alone to 4.6GHz from 3.3GHz stock at 1.23v and that's a much more power hungry chip than the 3600 or 3700X
Edit:
I did push to 4.7GHz at 1.3v but the CPU got way to hot but had no risk of damage for the motherboard :)
Prior Build Log/PC:
My board doesn't even have the additional 4 pin (molex) connection and ftr I can OC to 4.25Ghz on all cores with no issues.
Main Rig:-
Server:-
the 4pin is for ln2 overclocking ,  however if u rly want to put that in there are molex to 4pin converters , just make sure u dont get the pci-e converters xD but the mobo/eps ones
but then again why in the heck would u cheap out on a psu with a build like Ryzen 5 3600+5700XT
get a proper friggen psu
Corsair TXM if want to save or corsair RMx if you want to go high quality
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
Refer to PSU Tier List to see the quality of each PSU. If it's not on the list then it's probably very bad and you should avoid it.
Very good advise! Thank you very much
Edit:
Ok! That is very much! Thanks again for that comparison...helped alot
12 hours ago, Jakob22122003 said:
Very helpful thanks! I will watch some videos about them.
Not a real need to watch a video about them. Both are good quality units, except Rmx being better quality than the txm
