I've been trying to run my regular computer tasks with my iGPU while mining with my dedicated GPU. So far i've managed to change some things in the bios so that I could actually use my iGPU even though I had a card in my pci-e slot and that has worked well, and I can see that right now I am running on the intel graphics even though the gpu fan is spinning.
However, now when I try to startup cgminer it gives me this:
ADL found less devices than opencl!
There is possibly more than one display attached to a GPU
Use the gpu map feature to reliably map OpenCL to ADL
WARNING: Number of OpenCL and ADL devices did not match!
Hardware monitoring may NOT match up with devices!
how do I make it so that I can use my pci-e card to mine while letting my iGPU do the work?
I tried changing my bat file to this (so that it would run on my pci-e card):
cgminer --scrypt -o stratum+tcp://xxxxxxxxx -u xxxxxx.1 -p x -gpu-platform 2 --thread-concurrency 6144 -w 128 -I 19 -g 1
however when I run the bat file, it just opens the cgminer window for a split second and it disappears.
Any help?
"Common sense is not so common." -Voltaire
https://linustechtips.com/topic/110386-using-igpu-while-mining-with-dgpu/
No help?  :mellow:
Give it some time.  It is late here in the USA, and England is just waking up. Someone will help you later.
I personally can not help though. Sorry.
Desktop <dead?>
P8P67-WS/Z77 Extreme4/H61DE-S3. 4x4 Samsung 1600MHz/1x8GB Gskill 1866MHzC9. 750W OCZ ZT/750w Corsair CX. GTX480/Sapphire HD7950 1.05GHz (OC). Adata SP600 256GB x2/SSG 830 128GB/1TB Hatachi Deskstar/3TB Seagate. Windows XP/7Pro, Windows 10 on Test drive. FreeBSD and Fedora on liveboot USB3 drives.
Laptop <Works Beyond Spec>
HP-DM3. Pentium U5400. 2x4GB DDR3 1600MHz (Samsung iirc). Intel HD. 512GB SSD. 8TB USB drive (Western Digital). Coil Wine!!!!!! (Is that a spec?).
run "Cgminer -n" and post what comes back.
you might need to add --gpu-platform 1 to make it look for the PCIE lanes and not integrated.
Come fold while not gaming! http://linustechtips.com/main/forum/37-foldinghome-boinc-and-coin-mining/
Gaming Rig: i7-9700k 5GHz all core, GTX 1070, 16GB TridentZ, Buncha ssds...
Stream Machine: R7 1700, GTX 660 (lol), 16GB Corsair Somethingoranother, 120 GB SSD i've had since 2012.
Mobile Workstation: MSI-ALPHA :R7 3750H, RX 5500M, 16GB of some ram, 500GB SSD.
where do you have your monitor pluged in the gpu hdmi dvi output or on the mainbaord?
EOC folding stats - Folding stats - My web folding page stats
Summer Glau: Quote's The future is worth fighting for. Serenity
My linux setup: CPU: I7 2600K @4.5Ghz, MM: Corsair 16GB vengeance @1600Mhz, GPU: 2 Way Radeon his iceq x2 7970, MB: Asus sabertooth Z77, PSU: Corsair 750 plus Gold modular
My gaming setup: CPU: I7 3770K @4.7Ghz, MM: Corsair 32GB vengeance @1600Mhz, GPU: 2 Way Gigabyte RX580 8GB, MB: Asus sabertooth Z77, PSU: Corsair 860i Platinum modular
