need Help
Go to solution Solved by Gegger,
try and boot from it and if that doesn't work just do a fresh install
Don't forget to use the "Quote" feature or mention me ( @Gegger) if you want me to see your reply!
Community Standards // Forum Quickstart Guide // Floatplane // Forum FAQ // The Parrot Gang
Banned by Linus in the "banning game" thread who added insult to injury by putting this crap in my sig >(
WE ARE THE DARK SIDE Don't be a light theme peasant
             ........:oo:........
           o//ssssssssyhhysssss+////o               .''''''''''''''.
          mddmmm/::ddddddddddddddmmmyss::/mmN       |   PARTY ON   |
          o..+oodddmmmhhhhhhhhhhhdmmmmmdddooy       | ,............'
         h::oyyhddmmm+++///////////++++++mmmddy::s  |/
      Nyyo[[sddhyyyyy::::::::::::::::::::yyymmh//oyym
     h..:oohmm+:://///::::////////////////+mmmmms..sNN
     m++sddmmm+::hddhhy::+ddddddddddddddhhhmmmmmdhh+++d
    Nsssyyhmmhssooodmmhhh::+mmdyyyyyyyyddddddmmmmmmmmo::d
   mmd../mmmmmo::shhdmmhhh::+mmhooooooooyhhmmmmmmmmmmmyssdmm
  +++++smmdddo::///dmmhhh::+mmhooooooooooommmmmddddmmmdd/++m
 ``+hhhmmhoo/:::::oooooossymmhooooooooyyymmdoooooydddmmo//N
 ++:mmmmmy:::::::::::::/yyhmmhooooooooyhhmmd:::::+yyhmmyssddd
ooommmmmy:::::::::::::://ommhooooooooooommd:::::://shhdmm+..
yyhmmh++/::::::::::::::::+mmhooooooooyyymmd::::::::/++hmm+//
dddmmh++/::::::::::::::::+mmhooooooooyhhddh:::::::::::hmmysshhd
mmmmmdhhs::::::::::::::::+mmhoooooooohhhhhy:::::::::::hmmhhh``+
mmmmmh++/::::::::::::::::+mmdhhsooooodmm++/:::::::::::hmmsss``+
dddmmhoo+::::::::::::::::+dddddyssyyydmm::::::::::::::hmmsoo++o
dddmmdhho::::::::::::::::+hhdmmddddmmmmm::::::::::::::hmmsooNNN
mmmmmh///::::::::::::::::+hhdmmmmmmmmddd::::::::::::::hmmsoo++/
yyhmmdss+::::::::::::::::/ooydddmmmmmsoo::::::::::::::yddhyy::+
++ommmmmy:::::::::::::::::::ohhdmmddd/::::::::::::::::shhdmmsssNNNmmN
..+mmmmmy:::::::::::::::::::://shh+//:::::::::::::::::://dmmmmdoo+..o
``+dddmmhss+:::::::::::::::::::+++/::::::::::::::::::::::ooodddhhysshNNy++m ``+hhdmmdhhs///:::::::::::::::::::::::::::::::::::::::::::::yyymmmmmmmmo++hNNmdd ``+hhdmmdhhhhh+:::::::::::::::::::::::::::::::::::::::::::::::/hhhhhdmmmmmsoo... ``+ddmmmdhhhhhyyyyyyyyyyyo:::::::::::::::::::::::::::::::::::::+++++sdddmmdhhsss//+ ``+mmmmmhsshhhhhhhhhhhhhhy++/:::::::::::::::::::::::::::::::::::::::+ssyyydmmddd///hhd ``+mmmmmy::shhhhhhhhhhhhhhhhs:::::::::::::::::::::::::::::::::::::::::::::ymmmmmmmh../ ``+mmmmmy:://////////////ohhhyy+::::::::::::::::::::::::::::::::::::::::::///hddmmmhhs++s ``+mmmmmhssssssssssssssssydddddysssssssssssssssssssssssssssssssssssssssssssssdddmmmmmy::s ``+mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmhooh
https://linustechtips.com/topic/1103666-need-help/#findComment-12886140
Just now, lavacandy said:
he has the opposition to return the m.2 and get a new one should he do that
depends,won't really make a difference besides speeds if it's a diff ssd
https://linustechtips.com/topic/1103666-need-help/#findComment-12886147
he would get the same ssd he has
then it doesn't matter
https://linustechtips.com/topic/1103666-need-help/#findComment-12886151
so @gegger he should stay with the one he has it wont hurt his new cpu ???
it won't, and if it doesn't boot first try just do a fresh install
https://linustechtips.com/topic/1103666-need-help/#findComment-12886157
thank you can i send you the motherboard he he is thinking of getting its one of there because he can only buy them form bestbuy
sure,though i'm going to sleep soon
https://linustechtips.com/topic/1103666-need-help/#findComment-12886166
this is one he is planning to get a i9-9900k
https://linustechtips.com/topic/1103666-need-help/#findComment-12886170
