Hi!
So while tinkering with my OC on my 7700K I notice that the temps are quite high I am running it at 4.6Ghz, when doing a Prime95 (small FFT AVX turned off) I average at 85C.
Not sure what my ambient temps are.
Idle temps 38~43C.
Load 85C.
I currently cool the cpu with a NZXT Kraken X72, I’ve re-seated the cooler twice now, re-applied new thermal paste (Arctic Silver 5), made sure that pump is running at max, radiator fans set to performance mode (CPU), Liquid temp doesn’t seem to be going above 33C.
CPU: Intel I7 7700K @ 4.6Ghz[Non De-lidded] (voltage is set to offset mode, also tried with setting it manually) (according to CAM v peaks at 1.22).
Mobo: Asus Strix Z270-E.
Cooler: NZXT Kraken X72 Radiator is Front mounted.
RAM: Corsair Vengeance 16gb DDR4 3000mhz (XMP enabled)
PSU: Corsair RM750X 750W v2.
GPU: EVGA GTX 970.
Case: NZXT H700I
Is it just the a fact that I’ve lost the silicone lottery?
I have not De-lidded the cpu due to me not having neither the knowledge or tools to do so.
I have not updated BIOS if that matters.
Any help is very much appreciated.
Thanks.
https://linustechtips.com/topic/1103489-high-temps-7700k/
Silicon lottery is more GHz for the voltage, not really temps (temps go down with lower voltage, so given that silicon lottery winners need less volts for the same GHz, they run cooler as a side effect). That seems fine, Intel CPUs are always toasty when overclocked, and Prime95 typically pushes the CPU much harder than any real world load.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1103489-high-temps-7700k/#findComment-12884657
Okey, I know that intel tends to run hot but I keep seeing posts where they easily manage 5Ghz on 7700K without even delidding.
I kinda wanna push my computer a bit more just for fun but the temps themselves keep stopping me. ?
I know that 4.6Ghz is decent but I was hoping to be able to push it a bit further with the AIO...
Would it be worth buying the tool and liquid metal and try to de-lid ?
I'm just kinda scared of ruining my CPU cause then at that point I might aswell buy newer gen.
https://linustechtips.com/topic/1103489-high-temps-7700k/#findComment-12884675
85 in a stress test is perfectly fine, real world would be like mid 60s
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1103489-high-temps-7700k/#findComment-12884679
What are they getting that 5Ghz on? IIRC 4.7-4.8 is more common, 5Ghz is a golden chip but not as rare as older gens. You are pushing only 1.22v, the Intel recommended max is 1.35v, and brave lads push up to 1.4v sometimes, so you've got massive, massive voltage headroom (keep in mind some CPUs hit a hard limit and no amount of voltage will push them past that). Your thermals are what's letting you down, and AIOs for pushing CPUs hard are eh, about on par with an NH-D15 (teeny tiny bit behind actually).
If you really want to push OCs then delidding is usually the go-to, but if you mess it up you toast your CPU. Whether that's worth the risk or not is up to you.
^^^ My OCed 5820K idles at around 23C (It's in a custom loop with an RVII and 360 + 120mm rads), hits 58-60 max depending on load, Prime95 will still take it into the 80s (I avoid it now because it can damage this specific generation of CPU, so I use ASUS Realbench which pushes closer to real world temps).
Mouse: EVGA X17
https://linustechtips.com/topic/1103489-high-temps-7700k/#findComment-12884691
Seen people getting 5Ghz on 1.35v, But maybe Ill just have to settle for 4.6Ghz.
I Tried doing realbench R22 but I kept getting the same temps as when doing Prime95.
Anyhow thanks for the help, Its much appreciated!
https://linustechtips.com/topic/1103489-high-temps-7700k/#findComment-12884712
