So basically since my dGpu died, I'm stuck with my iGpu which is the intel hd 4400 which isnt even that bad considering it's kinda old and integrated.
But I've encountered an issue with it.
The games run terrible, like league gets barely 30fps on 720p all low, performance mode set in both windows and drivers.
In some games it's even worse than my t5500 and gma 945 laptop.
Reinstalled drivers, put new drivers, modded drivers, messed with it in bios changing vram, setting default display device.
Same, I tried it with DDU, same.
Cpu isn't throttling, neither is the iGPU.
Windows is like 2 weeks old, maybe even less.
https://linustechtips.com/topic/1102596-igpu-problems/
This iGPI wil give problems just make sure you install all the drivers from their site and what not.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1102596-igpu-problems/#findComment-12876630
1 minute ago, qyvu said:
yup
If the gpu usage is 100% then that means you can't really get more performance out of it.
You can try looking at the igpu clockspeed, but afaik on intel those aren't overclockable.
I only see your reply if you @ me.
https://linustechtips.com/topic/1102596-igpu-problems/#findComment-12876655
It is going to the maximum clock speed, but the thread isn't me  having expectable low performance, the performance i get is WAY below what others do.
https://linustechtips.com/topic/1102596-igpu-problems/#findComment-12876657
But only if that board/cpu can use faster RAM. Haswell's only chipset that can use RAM faster than 1600 is Z87 I believe. H87 and lower are limited to 1600 or even 1333. Possibly you could overclock the iGPU with Intel XTU, I've done so with a desktop Haswell before.
https://linustechtips.com/topic/1102596-igpu-problems/#findComment-12877326
10 hours ago, qyvu said:
Might be, since It's only a single stick of 1600mhz ddr3 ram
Oh. That is single channel. If you had dual channel you would have much faster, atleast that is the case with ryzen igpus.
https://linustechtips.com/topic/1102596-igpu-problems/#findComment-12877720
