I've been trying to experiment with Linux while I wait for my new computer to arrive but so far, I'm just frying USBs. The first I installed the pop-os iso onto then realized I did something wrong. I went to format the drive but... the drive wasn't being picked up. I then went into disk manager and wiped it clean thinking this would help. It didn't. Now I still can't format it. I've tried formatting every way possible from right clicking to cmd commands. Half of them pick up the drive but pop out some sort of error, the other half refuse to acknowledge it's existence. Sometimes it would show up but wouldn't even show it had the capability of storing data. One of the errors was along the lines of "install drive into usb F:" After realizing this was probably a lost cause, I wrote the usb off and ordered another one. This time, with the new usb, I managed to use a program to make the usb a bootable drive, with the pop-os iso. After much finagling in the bios I managed to launch into pop-os. The installer experienced an error... I don't remember what the error was but I "fixed" it by just using the demo mode. I then proceeded to try to change the desktop to KDE using terminal commands. It was gong well until it wasn't. Apparently, my drive was out of space. It's a 32gb drive so I doubt this is the case and search around for how to look at total space on a disk in gnome. I find that the disk manager, or whatever it was called and realize the demo version is limiting me to 2gb, no wonder I ran out of space... I then try to install it again, from within the demo version as there's a button to install it. It looks like it's going fine until I get to selecting the partitions. I use the custom option so I don't erase my computer's drive on accident. It won't let me select any of the partitions but the buttons are working. I select the partition manager and at this point some error happened that landed me on a black screen with a flashing underscore. I wait on this screen for several minutes without change, I then try practically every key on the keyboard, and after realizing nothing is happening I turn my computer off to retry. Upon going back into the boot selector and selecting my usb drive, apparently my drive is no longer a bootable drive. After anther restart and more bios kerfuffle I get back into windows and take a look at the drive. Show's it's blank again, not empty, blank. Just like the other usb, it doesn't even show a storage bar under it in the file manager. Try to format it like I did the other one, it too apparently needs to have a drive inserted. At this point I stop messing with it and come here as I clearly don't know what to do and don't want to break it further. Please... help...
Did you try wiping the drives with diskpart (clean command)?
It's pretty difficult to break flash drives just using software, unless you know exactly what you're doing (flash incorrect config/firmware to flash controller for example)
+°´°+,¸¸,+°´°~ Glorious PC master gaming race :wub: ~°´°+,¸¸,+°´°+
BigBox: Asus P8Z77-V, 3570k, 8GB Ram, Intel 180GB & Sammy 750GB, HD4000, W7
PiBox: Rasberry Pi, BCM @ 1225Mhz ^_^ , 256MB Ram, 16GB Storage, pIO, Raspbian
