Sound cards
Go to solution Solved by Bananasplit_00,
A sound card provides a way for your computer to output sound. You have one built in to your motherboard or you can get discrete ones that use either an expansion slot or a USB port. They tend to provide more features and tuning than the one built-in to the motherboard along with improved quality. You don't need a discrete card generally as the sound from the motherboard is usually pretty good these days
What is a sound card?
What does it do?
What are its benefits?
Is it necessary for a pc build?
What is their interface?
What's the difference between the audio interface on my motherboard and a sound card?
PC: Ryzen 5 2600, 16GB 3200mhz RAM (8GBx2), Gigabyte B550M DS3H, GTX 1050 2GB, 650W Semi-Modular PSU80+ Gold
Phone: Poco F3 8GB + 256GB
Audio: Samson SR850s
Sound Card: SoundBlaster Play 4 USB sound card
IEM: planning to get the KBEAR KS2s
Please be patient with me, I'm fatally dumb and its honestly a miracle I've made it this far
https://linustechtips.com/topic/1100857-sound-cards/
Builds:
https://linustechtips.com/topic/1100857-sound-cards/#findComment-12862733
  • 3 weeks later...
Thanks
https://linustechtips.com/topic/1100857-sound-cards/#findComment-12915118
