Hi Im having problems with my pc I just bought a new case CM H500 and 3 ARGB fans and a m. 2 ssd and I rebuild my entire pc to this new case now I'm in windows and sometimes while just doing some general stuff browsing etc. Sometimes right after boot it just shuts off no shutting down screen just instant off but only 1 rgb logo on my motherboard is still on
Pls help
Specs:
CM h500
512gb adata xpg spectrix m.2
500gb 860 evo
1tb barracuda
3x mf120r
2x mf200r
Gtx 980 msi
Aorus B450 elite
R5 2600
Stock cooler
2x 8 gb 3000mhz ram
500w masterwatt lite psu
 I really need help
And to let my rgb fans work with coolermaster masterplus and then rgb fusion I need the 40 dollar controller right?
https://linustechtips.com/topic/1100202-i-really-need-help/
Could be psu related..
have you tried with a different psu?
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1100202-i-really-need-help/#findComment-12857541
13 minutes ago, Hypoxz said:
I don't have another psu but I'm thinking of buying a new one
Corsair TXM if you are on a lower budget or if budget doesn’t matter grab a Corsair RMx or be quiet straight power 10/11
https://linustechtips.com/topic/1100202-i-really-need-help/#findComment-12857599
Yeah I was looking at the rm750x or rm850x like 10secs ago i started up a game and It crashed again the crashes are just power issues?
https://linustechtips.com/topic/1100202-i-really-need-help/#findComment-12857611
RM550x will be plenty mate. No need for 750/850.
edit; I power a 2700x + 2070 with that exact psu. (Check sig)
https://linustechtips.com/topic/1100202-i-really-need-help/#findComment-12857619
And when it crashes and I turn it straight back on it crashes in like 1min and if I wait turning it on it may last 20mins
https://linustechtips.com/topic/1100202-i-really-need-help/#findComment-12857627
4 minutes ago, Hypoxz said:
Yeah but I currently have 500w so how does this make the difference
Because your current psu is a shit quality one.. wattage isn’t the main thing - it’s more about the quality of the internal components and overall unit.
https://linustechtips.com/topic/1100202-i-really-need-help/#findComment-12857640
Have you monitored any temps of the components? I mean to me it’s seems a psu issue to be fair
https://linustechtips.com/topic/1100202-i-really-need-help/#findComment-12857644
When you say 1RGb logo, is it a red or white led? Could be a debug led
1 minute ago, Hypoxz said:
I hope it's the psu and that I don't buy a new psu and it still crashes
https://linustechtips.com/topic/1100202-i-really-need-help/#findComment-12857687
It's the aorus logo on my mb and it's the color I put in in rgb fusion it's orange
Hmm ok. To me it still sounds like a psu problem
https://linustechtips.com/topic/1100202-i-really-need-help/#findComment-12857705
22 minutes ago, Hypoxz said:
Okay thx I'm gonna order a new psu and also the rgb controller maybe IL add in a dark rock pro 4
A noctua u12s would be sufficient for this cpu. I know they fan colours aren’t the best tho ? but if you can/want just get th DRP4.
let me know once you have the new components of the issue has resolved itself !
https://linustechtips.com/topic/1100202-i-really-need-help/#findComment-12857781
I Can probably pick them up tomorrow but got my current psu out of my case reconnected it reinstalled windows on data ssd then reinstalled on m. 2 and now it works....
But still getting the components cuz also cpu edc is high in red and it's better
https://linustechtips.com/topic/1100202-i-really-need-help/#findComment-12858349
