Power To GPU
Go to solution Solved by minibois,
So you mean you have a PSU with only one 6+2 pin PCIE power connector, but a GPU with with a 6+2 and 6 pin connector?
Best case scenario it will run, until you are fully loading the GPU in a game and it will crash, worst case it won't start up at all.
Don't do this though, if your PSU only has one PCIE power connector, it likely is not of sufficient quality with a beefy GPU.
2 minutes ago, thdevi said:
what would happen if i plugged a 6+ 2 into a 8+6 Slot on a gpu would i just not get a signal
I wouldn't.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1099710-power-to-gpu/#findComment-12853741
https://linustechtips.com/topic/1099710-power-to-gpu/#findComment-12853744
I know i have enough power to power it iv ordered a molex to 6pin for it which apparently will work
https://linustechtips.com/topic/1099710-power-to-gpu/#findComment-12853751
molex to 6 pin is not recommended, not for a system you care about.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1099710-power-to-gpu/#findComment-12853786
Just now, thdevi said:
why what will happen? also its not perminant just for a few weeks
The power delivery of molex is not appropriate for a power hungry GPU. Anything from the PSU dying to cables melting is possible. I speak from firsthand experience
Primary PC:
PSU tier list
https://linustechtips.com/topic/1099710-power-to-gpu/#findComment-12853801
how long did yours take to meal or your psu dying also its a 2xmolex to 6 pin if that makes a differance
https://linustechtips.com/topic/1099710-power-to-gpu/#findComment-12853806
I was running a 780 off a PCIe 8 pin + a dual molex to 6 pin, that was the death of both the PSU and the motherboard. When a crappy PSU dies it usually takes something with it.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1099710-power-to-gpu/#findComment-12853810
Is Mine Crappy
https://www.amazon.co.uk/gp/product/B00JKVHKSU?pf_rd_p=330fbd82-d4fe-42e5-9c16-d4b886747c64&pf_rd_r=Q6SYC9XRT7F12AZ5RK0Z
https://linustechtips.com/topic/1099710-power-to-gpu/#findComment-12853822
4 minutes ago, thdevi said:
the integrator is a super cheapo model. definitely not recommended.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1099710-power-to-gpu/#findComment-12853836
6 minutes ago, thdevi said:
What GPU are you trying to power with that firebrick?
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1099710-power-to-gpu/#findComment-12853838
Maybe you could put the power limit to like 50% or so so you shouldn't overload it but can enjoy it for the time being? :)
PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular  - Case: Corsair Obsidian 450D  - OS: Windows 7
https://linustechtips.com/topic/1099710-power-to-gpu/#findComment-12853848
33 minutes ago, thdevi said:
980 my friend has been using a molex to 6 pin for almost a year and it worked fine and he has a 980 also
Some win the gamble, some lose. I choose not to gamble at all.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1099710-power-to-gpu/#findComment-12853918
