6 minutes ago, Tim1304 said:
Hello, everybody!
I am building a retro 486 gaming PC and the CERAMIC cpu I bought has some old thermal paste on it. Will rubbing it off with alcohol do? Is it possible that I will damage the chip somehow?
No, you should be fine. I usually even use wet cleaning cloths that are waterbased and it's fine.
https://linustechtips.com/topic/1099599-help-please/#findComment-12852978
