Hey all, so I bought a used fractal design focus g mini case and when I got it home I realized it was missing the power/reset cable from the front io, aswell as the audio cables. It had non of the little annoying single and double prong cables. There are 2 empty 4 pin connections under the power/reset switch and audio Jack's. So my question is. Can I buy these cables anywhere? Iv looked around and can only find actual buttons not just a 4 pin female to 2 pin female cord. Even a 2-2 would work as I only need the power switch not the reset or audio. A bonus is the guy gave me my money back plus let me keep the case ;), any help is appreciated. Thanks
https://linustechtips.com/topic/1099523-front-io-cable-missing/
May be hard to find. Maybe ask Fractal support? :)
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1099523-front-io-cable-missing/#findComment-12852362
