First time builder... wanting to go overboard so I wouldn't have to upgrade for awhile... planning to stream amd run all games at 1080p60 minimum. Also wanting to start video editing...  any opinions or tips are appreciated...
Ryzen 7 3700x, hyper 212 rgb black edition, asrock x570 taichi, Trident z ddr4-3600, WD black 2tb, 1tb adata ssd, 970 evo 1tb m.2, asus rog rtx 2080 super, super sonic focus 850w 80+ gold, and the fractal design meshify c...
https://linustechtips.com/topic/1099444-need-help-for-build/
What's the budget and location?
https://linustechtips.com/topic/1099444-need-help-for-build/#findComment-12851688
Future proofing is a terrible idea. Since you can't see the future you can't know what lifespan you're giving your PC. Just buy for the now and upgrade when you need to, it'll save you money for sure.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1099444-need-help-for-build/#findComment-12851693
