I am wondering if there is a way to make a program that is minimized run as if it is open, I need to know this because on the game im playing It runs at 80 fps and when i minimize it, it goes down to 15 fps. And you might ask why do i need more fps if its minimized its cause in the game im playing you can auto hunt and when its at 15 fps its basically in slow mo, the game is Conquer Online 3.0 Btw. I haven't been able to find anything about this so it would be appreciated if someone knows, ty
https://linustechtips.com/topic/1099164-i-need-help/
I know what you mean, and i'm curious about  a sollution to this. Won't know when i need it :) Have started to follow this thread. (think i had this issue when i was playing X3 and waiting overnight for my AI traders to make money)
What seems to happen is that when a game loses focus, it will go into some sort of powersaving mode.
Gamesystem: X3700, 32GB memory @3200mhz, GTX1080 Hybrid
Unraid system: Epyc 7352, 24/48, 96GB ECC buffered @2666mhz, 2x GT710, GTX1050Ti
https://linustechtips.com/topic/1099164-i-need-help/#findComment-12849437
Can you run it in windowed mode instead of full screen?
Have you tried setting priority in windows so its high?
Folding Stats
SYSTEM SPEC
AMD Ryzen 5 5600X | Motherboard Asus Strix B550i | RAM 32gb 3200 Crucial Ballistix | GPU Nvidia RTX 3070 Founder Edition | Cooling Barrow CPU/PUMP Block, EKWB Vector GPU Block, Corsair 280mm Radiator | Case NZXT H1 | Storage Sabrent Rocket 2tb, Samsung SM951 1tb
PSU NZXT S650 SFX Gold | Display Acer Predator XB271HU | Keyboard Corsair K70 Lux | Mouse Corsair M65 Pro
Sound Logitech Z560 THX | Operating System Windows 10 Pro
https://linustechtips.com/topic/1099164-i-need-help/#findComment-12849975
