Monitor Has Pixel Noise on Black Screens
Solved by Turtle Rig,
3 hours ago, NickB said:To add on, after a bit, my desktop background turns black and any desktop icon I pass my mouse over restores some chunks of the background.
I assume you have no overclock on your CPU and GPU ? Also can I assume you have done DDU ? Monitor making that noise is not good. All you did was change monitors... it shouldn't dot his. I think you should talk to MSI RMA and explain to them the pixel noise on black screen and do a RMA and I hope its under warranty. good luck
