4 minutes ago, tydraestor said:
So im in a visual basic class in college and i have a laptop and a tower, is there anyway to share files between the two if i connect them both with an Ethernet cable?
Use something like google drive, Dropbox etc ?
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
3 minutes ago, tydraestor said:
college routers dont allow it through. thats why im not using it. They also dont allow chromecasts and they dont work on the wifi either
Use the TeamViewer build-in VPN to bypass those restrictions. Or just use a network drive.
"Mankind’s greatest mistake will be its inability to control the technology it has created."
Use a cloud storage system that allows local syncing.
If this is for programming, I'd argue sign up for Github or some other version control system so you can start learning how to use one.
You can but how easy it will be depends on how Windows is feeling. The easiest and best method is to use cloud storage. Only because then you have your files also backup off site. Google Drive and Microsoft's One Drive work pretty well.
