I guess you using a Desktop PC, then..
The maximum limit of cpu temp (or can be refered as Tjunction) is rather high than your temp (around 100c). Aside from this, usually GPU are uses are more demanding than CPU (depending on what game are you playing). So, also check your GPU temp and air circulation in your case.
https://linustechtips.com/topic/1098350-my-cpu-temps/#findComment-12843567
9 hours ago, Oceanman1342 said:
well see i think its causing my games to crash cause my core temp can get high as 60c when playing games
60 or actually pretty low for a load.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
https://linustechtips.com/topic/1098350-my-cpu-temps/#findComment-12843853
