Not sure what to put, new to the pc world, I’ll explain the best I can  I built a PC about seven months ago Since the build occasionally I would run into the blue screen of death 0cx000000e tried fixing that issue but not sure if I did. Leading up to today I tried booting the pc up to get no post/boot and a red cpu light. I tried the troubleshooting for that mother work then I Tryed cmos reset jumper for 24hrs. The pc is alive again I checked bios looked good. So I played games for a couple hrs then put the pc to sleep, about hr later came back stared pc and my internet was not working said I had no network driver. Powered down the pc and to get a red cpu light again did the cmos reset again and pc was up and running again. So right now the pc is up and running not sure what to check or do from here I did play some games and everything seems fine after playing the game I did I counter I clicking noise coming from my psu fan I light click...
any help would be great thanks
my build
ryzen 5 2600
asus b450-f gaming mobo
2x8gb t force delta ram 3000MHz
gtx2060
psu 650BQ EVGA 80bronze
coolmaster aio liquid cooler
ssd250
hdd2tb
https://linustechtips.com/topic/1098304-psu-mobo-ram-help/
OC the RAM to 3200Mhz
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1098304-psu-mobo-ram-help/#findComment-12842668
