Temps are high
Go to solution Solved by Origami Cactus,
1 minute ago, CrazieChipmunk said:
60-75
then all good.
Just now, CrazieChipmunk said:
idle
What clockspeed, what processor?
With PBO enabled my 3700x "idled" at 50-70c, because of all the background tasks causing the cpu to wake every once in a while etc
Right now i "idle" at 40-50c, which seems the norm with ryzen processors.
I only see your reply if you @ me.
https://linustechtips.com/topic/1098193-temps-are-high/#findComment-12841679
ryzen 3600, in the morning it was only 43-46 so i think its just the heat outside after all this is the nzxt h500 its in
https://linustechtips.com/topic/1098193-temps-are-high/#findComment-12841682
It seems like a fine temp, i wouldn't worry about it.
What are your temps under load?
https://linustechtips.com/topic/1098193-temps-are-high/#findComment-12841686
temp reporting is all over the place.
Ryzen master and core temp can either be close like this screenshot. Or i have seen coretemp report 10c higher then Ryzen Master.
Ryzen Master is also not accurate for reporting stuff either.
Hers my chip at its daily driver 4.4ghz oc in Georgia on a custom loop. Loads around 65c
https://linustechtips.com/topic/1098193-temps-are-high/#findComment-12841836
