So it would seem that I've gotten some birthday money, so I'd like to invest a bit further into photography, and a tripod is next on the list. "Inexpensive but not cheap" is the idea. I found this one on Amazon. Opinions?
https://www.amazon.com/Victiv-Camera-Aluminum-Monopod-72-inch/dp/B07JZCYWLZ/ref=mp_s_a_1_9?keywords=tripod&qid=1566784874&s=gateway&sr=8-9&th=1&psc=1
My eyes see the past…
My camera lens sees the present…
https://linustechtips.com/topic/1098048-inexpensive-tripod/
I quite like the Manfroto range, i have a few of their tripods and monopod.
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
https://linustechtips.com/topic/1098048-inexpensive-tripod/#findComment-12840633
https://linustechtips.com/topic/1098048-inexpensive-tripod/#findComment-12840642
@Zodiark1593I have that one and its a good tripod.  I have a Canon 70D and a 1200D and both go on this tripod with no issues.
Internet Speed.....
https://linustechtips.com/topic/1098048-inexpensive-tripod/#findComment-12840664
The Manfrotto or the Victiv?
https://linustechtips.com/topic/1098048-inexpensive-tripod/#findComment-12840667
@Zodiark1593Manfrotto.
Internet Speed.....
https://linustechtips.com/topic/1098048-inexpensive-tripod/#findComment-12840671
Thanks for that. So that's two for the Manfrotto.
I currently use a Canon G7X MkII, so quite the light setup as of now, should be no problem whatsoever, besides perhaps looking a tad odd. Though having the headroom for expansion would be nice in the unlikely event I get a paid job in the future too.
https://linustechtips.com/topic/1098048-inexpensive-tripod/#findComment-12840693
U will have no problem what so ever on a camera so light with this tripod and u have plenty of room to maneuver if u decide to get a bigger camera like a DSLR.
Internet Speed.....
https://linustechtips.com/topic/1098048-inexpensive-tripod/#findComment-12840696
Went ahead and pulled the trigger on the Manfrotto. I've a couple ideas already, though I won't be able to implement them until the weekend. :D
https://linustechtips.com/topic/1098048-inexpensive-tripod/#findComment-12840759
@Zodiark1593I'm sure u wont be disappointed.
Internet Speed.....
https://linustechtips.com/topic/1098048-inexpensive-tripod/#findComment-12841561
Disappointed I am not. This thing is a brilliant tripod. Being able to go really slow on the shutter with near impunity feels almost liberating. Given how light the camera is, I can keep the swivel on a very light resistance to move the camera easily, and it will stay put. Collapsed down, it's barely taller than the Wal-Mart tripod (the one meant to put on a table).
Another thing to experiment with is using my off camera flash in conjunction with tripod. As my camera lacks a hotshoe, it can be a pain to get the flash to fire in slsve mode. With the tripod holding the camera though, this can free me up to line up the sensor with the pop-up flash, and better utilize the flash as a result.
https://linustechtips.com/topic/1098048-inexpensive-tripod/#findComment-12846265
@Zodiark1593 Im glad you like the tripod.
Just experiment now and have a good time.
Internet Speed.....
https://linustechtips.com/topic/1098048-inexpensive-tripod/#findComment-12847370
Consider grabbing a hot shoe/tripod mount adapter: B&H has 'em for about $12.
https://www.bhphotovideo.com/c/product/764588-REG/Nisha_HTS_T_Hot_Shoe_Tripod_Mount.html?ap=y&smp=y&lsft=BI%3A514&gclid=EAIaIQobChMI1c3NrKqo5AIVjYbACh0pwwZtEAQYESABEgKKgPD_BwE
Depending on your use case, this lets you put the flash on a stick (like one extended leg of your tripod) and hold it out into line of sight for the optical trigger. Then you, the camera, and the flash are all functional and portable.
Or, pick up this to tripod up the flash, cheap modifiers like umbrellas, whatever, on the tripod. Then you can place your light and hold your camera.
https://www.bhphotovideo.com/c/product/546375-REG/Manfrotto_026_026_Swivel_Umbrella_Adapter.html?ap=y&smp=y&lsft=BI%3A514&gclid=EAIaIQobChMI1c3NrKqo5AIVjYbACh0pwwZtEAQYEiABEgKvTfD_BwE
Have fun with ND filters and rear curtain shutter flash syncing stuff :-)
https://linustechtips.com/topic/1098048-inexpensive-tripod/#findComment-12849981
Have fun with ND filters and rear curtain shutter flash syncing stuff ?
 DIY shroud with a strip of aluminum inside also gets me a lot more effective range in firing my flash, even in daylight with the pop-up on low power. My other Wal Mart table tripod should help with this.
Experiments also tell me that a flash can be fired with the camera's own sent down via fiber optic, so one could theoretically 3d print shrouds on both ends with a fiber optic to connect them, effectively creating an optical hotshoe of sorts.
https://linustechtips.com/topic/1098048-inexpensive-tripod/#findComment-12850278
  • 2 weeks later...
Not sure how, but a fairly substantial chunk of metal seems to have found it's way into one of the legs of this tripod and I can't seem to find a way to disassemble the leg enough to extricate the object. Even with the leg removed, the plastic black cap is riveted into place, the locks seem to have no visible means of coming apart, and the object is much too large to come out the bottom leg. Any help here, or RMA?
Edit: succeeded in getting the piece out. It was plastic, so some breaking it apart with a lot of persistence eventually rewarded me.
https://linustechtips.com/topic/1098048-inexpensive-tripod/#findComment-12874496
