Best budget cooler for Ryzen 3600?
Go to solution Solved by Energycore,
3 minutes ago, Daventh said:
Yeah, think it's the same as GT but without RGB for half the price, yes please would like to see a review of it.
https://www.tomshardware.com/reviews/deepcool-gammaxx-400-slim-tower-cpu-cooler,4460-2.html
This review by tomshardware shows it handily beating the NH-U12S and the Be quiet! Shadow Rock Slim in performance.
If you don't like the cheap-ish looking fan you can buy an NF-F12 and still stay below the price of the more premium offerings
It seems like the Wraith Stealth is not good enough or something is wrong in my setup, i get 60-75C in gaming but 95C (causing the CPU to throttle) under all core workloads, looking for a 45 or less cooler, can stretch it to 50 but my budget is very tight, and 165mm tall as a maximum. Been looking at a deepcool gammaxx gt, hyper 212 black edition and a Scythe Mugen 5, but i cant find a definite answer to which will perform better, dont care much about noise or RGB just that temps improve.
https://linustechtips.com/topic/1097992-best-budget-cooler-for-ryzen-3600/
24 minutes ago, Daventh said:
snip
We cleaned your thread, sorry that it was removed for a bit.
If you don't care much about aesthetics, and want a really high performance cooler for cheap, look for the Deepcool GAMMAXX 400. It's usuallp $20 in the US and performs like $40-$50 coolers from more premium brands.
I can link you the review if you want :)
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
Computer Specs:
