Microphone sounds muffled
Solved by Semper,
Access your microphone properties (right click the speaker on your toolbar, open "sound settings", under input click "device properties", then click "additional device properties"), switch over to the advanced tab and see what your default format sample rate is.
Windows updates have somewhat frequently, but sporadically, reset the sample rate down to 1 channel, 11025 bit, which sounds as though you're talking with your head inside a box.
