How does it look?
http://pcpartpicker.com/p/2LlzG
This is my first build ever. I currently *survive* on a 2007 HP Pavillion with a GTX 760 installed, which I will put in this new one. I went for the 3.2GHz i5, because I really want to use Steam Home Streaming to my MacBook without it sucking (like it does on the current C2D).
The Builder Series PSU is what I currently have, and it works perfectly, but I'm giving the current tower to my dad with the original 9600GT, so it still needs a PSU.
So, how does it look? The price is pretty much as much as I want to spend, as the GPU was already $250 of my budget. Does anyone who uses the Steam Streaming have experience, and think this would work well? It'd be 720p, as that's my MacBook's max.
Thanks!
Noah
EDIT- oops, I have a mid-ATX tower with a micro-ATX mobo. Will fix!
EDIT 2- just realized that doesn't even matter.
https://linustechtips.com/topic/109765-how-does-it-look/
PC: CPU: Intel i7-4790 MB: Gigabyte B85N RAM: Adata 4GB + Kingston 8GB SSD: Samsung 850 EVO 500GB GPU: XFX GTR RX 480 8GB Case: Advantech IPC-510 PSU: Corsair RM1000i KB: Idobao x YMDK ID75 with Outemu Silent Grey Mouse: Logitech G305 Mousepad: LTT Deskpad Headphones: AKG K240 Sextett
Phone: Sony Xperia 5 II
https://linustechtips.com/topic/109765-how-does-it-look/#findComment-1466596
Ok, added some of that. The cooler in particular made sense. thanks!
https://linustechtips.com/topic/109765-how-does-it-look/#findComment-1466641
I picked that cooler because it isn't too much more expensive than the one you picked. Otherwise I would go for Gelid Tranquillo.
https://linustechtips.com/topic/109765-how-does-it-look/#findComment-1466779
Thanks!
Noah
if ur not guna overclock i wudd suggest dont even buy a cooler and stick wit the stock one save money for a better cooler in the future
System Specs~~~~~
Case-Corsair Air 540                                   CPU-i7 4770k                           Ram-Corsair Vengeance 16 Gbs    PSU-Corsair RM1000
Motherboard-Asus Maximus VI Formula    Graphics-Asus Gtx 780 Ti x2     CPU Cooler-Corsair H100i               SSDs-Corsair Force GS 128/360 Gb
https://linustechtips.com/topic/109765-how-does-it-look/#findComment-1467670
How much money do you want to spend?
Don't you need a copy of Windows as well?
Which GTX 760 do you have?
Edit:
This one is about $150 more than your current build, but I think it will look better. Also, it has an SSD for added responsiveness.
CPU:  Intel Core i5-4570 3.2GHz Quad-Core Processor  ($199.99 @ Newegg)
CPU Cooler:  NZXT Respire T20 68.8 CFM Sleeve Bearing CPU Cooler  ($29.96 @ Amazon)
Motherboard:  Gigabyte G1.Sniper B5 ATX LGA1150 Motherboard  ($97.55 @ Newegg)
Memory:  A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory  ($72.99 @ Newegg)
Storage:  Crucial M500 120GB 2.5" Solid State Disk  ($79.99 @ Amazon)
Total: $645.45
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-02-02 17:42 EST-0500)
Aesthetics of rigs matter
42
If you're interested, participate in LTT Build Offs
https://linustechtips.com/topic/109765-how-does-it-look/#findComment-1472809
How much money do you want to spend? Don't you need a copy of Windows as well? Which GTX 760 do you have? Edit: This one is about $150 more than your current build, but I think it will look better. Also, it has an SSD for added responsiveness.  PCPartPicker part list / Price breakdown by merchant / Benchmarks CPU:  Intel Core i5-4570 3.2GHz Quad-Core Processor  ($199.99 @ Newegg) CPU Cooler:  NZXT Respire T20 68.8 CFM Sleeve Bearing CPU Cooler  ($29.96 @ Amazon) Motherboard:  Gigabyte G1.Sniper B5 ATX LGA1150 Motherboard  ($97.55 @ Newegg) Memory:  A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory  ($72.99 @ Newegg) Storage:  Crucial M500 120GB 2.5" Solid State Disk  ($79.99 @ Amazon) Storage:  Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($59.99 @ Amazon) Case:  NZXT NZXT H230 White ATX Mid Tower ATX Mid Tower Case  ($59.99 @ Newegg) Power Supply:  Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.99 @ Newegg) Total: $645.45(Prices include shipping, taxes, and discounts when available.)(Generated by PCPartPicker 2014-02-02 17:42 EST-0500)
Yeah, where it was is what I want to spend :P, but this build looks very promising; I'll probably add an SSD later. The 760 is a PNY Enthusiast Edition (2GB). And no, I have a copy of 8.1 already. Saves a bunch!
https://linustechtips.com/topic/109765-how-does-it-look/#findComment-1472946
