I want to build an HTPC for around 600 USD(including OS). Not including peripherals
Requirements:
-5GHz Wireless-N
-Must be mITX
-No graphics card, but have PSU headroom for a cheap one later(like a GTX 660)
-Must have a DVD drive
-No HDD (will add later)
-Must have 120GB SSD boot drive
-Must be powerful enough for Steam In-Home Streaming
-Have one 8GB stick of RAM
My though:
http://pcpartpicker.com/user/worthtalley/saved/3C5S
Edit: Apparently the hyperlink worked :)
System Specs - CPU: i7 4770K - RAM: 8GB(2x4GB) Vengeance Pro - Motherboard: Maximus VI Gene - Case: Modded PowerMac G5 - CPU Cooler: H100i - PSU: AX860i - SSD: Samsung 840 Series 120GB and Kingston V300 120GB - HDD: Seagate Barracuda 1TB - Graphics Card: 2x GTX 780 - Case Fans: SP120s and Spectre 140s - Headphones: HD700, Alpha Dog, SE215
Sony A7R w/ Zeiss 55mm F1.8
https://linustechtips.com/topic/109746-htpc-build-help/
looks good. the cpu is very efficient but its overkill but since you mentioned gtx 660 maybe you need it.for the psu go with a cx 430 modular. its enough for gtx 660/760
Thanks for the PSU advice I didn't really know what kind of headroom you needed for lower end cards
https://linustechtips.com/topic/109746-htpc-build-help/#findComment-1466468
  • 3 weeks later...
