I have the B450 GAMING PRO CARBON AC motherboard and there are some drivers im not sure what is needed and what is optional (im new to this)
they are the
  • AM4 RAID Driver
  • AMD Chipset Driver
and not sure if I need both or just one of these drivers
  • Realtek HD Universal Driver
  • Realtek High Definition Audio Driver
and not sure which utility to get
  • APP Manager
  • Command Center
  • CPU-Z MSI GAMING
  • Gaming Lan Manager
  • Live Update 6
  • MSI Gaming APP
  • MSI Smart Tool
  • Mystic Light 3 (Motherboard has RGB)
  • Nahimic 2
  • Nahimic 3
  • Realtek Audio Control
  • Super Charger
  • X Boost
https://linustechtips.com/topic/1097197-motherboard-driver-help/
All of those are optional and not required.
The other things should be installed (especially the Chipset driver) but if your system is behaving and booting fine, skip the RAID driver, unless you use RAID
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
19 minutes ago, kirbydude47 said:
AM4 RAID Driver
AMD Chipset Driver
Mandatory.
Redundant because of Realtec HDAD.
APP Manager - not needed unless you want to tweak a hect ton of stuff in one place instead of 3-5;
Command Center - not needed unless you want to use your Android phone to control RGB on the motherboard;
CPU-Z MSI GAMING - unless you plan on monitoring your CPU in any way possible (which can be done better with HWInfo64) AND you want MSI sking, not needed;
Gaming Lan Manager - not needed, it's QoS service, will screw up other connections like video buffering;
Live Update 6 - not needed unless you want all MSI software from this list to be updated in one click;
MSI Gaming APP - not needed, don't even install if there is software like Dragon Center or APP Manager;
MSI Smart Tool - not needed, there's a better analogue called Rufus;
Mystic Light 3 (Motherboard has RGB) - if you want to fine tune RGB, then it is required;
Nahimic 2 - not needed, you can do everything it does (except some FX that don't do any good to sound) in RAC;
Nahimic 3 - same as Nahimic 2, but 1UP!;
Realtek Audio Control - Required for Realtec HDAC, so it's needed;
Super Charger - doesn't work so do not install;
X Boost - not needed, since it doesn't do anything good.
Purify your Windows 10/11, don't give Microsoft anything that you don't want to share.
https://drive.google.com/open?id=1ZwVs9zrM493rjD42E2Pf0YcOkaW92ZUo
Tips for folding on laptop:
Lazy man wants upgrades from the sky.
https://stats.foldingathome.org/donor/Spakes
