Mouse Problem
Solved by Levent,
Assuming you got W10, you got couple of settings that might cause this issue.
Settings app > Devices > Mouse.
You can change the slider bar I marked in red, OR click on that Additional mouse options I marked in green then change settings in
Wheel tab. (You can try my settings, they were the default settings for W10, I never changed them)
