I decided to wait out the recent storm of tech releases (I'm glad I did), and I think I'm safe to build now.
This system is mostly going to be used for game development / design and digital art (Unity, Unreal Engine 4, Adobe Creative Suite)
Some gaming, but mostly Rocket League and Destiny 2, not too intensive.
My budget is $1500 USD, I can't go more than $50 USD over that
I already have all the peripherals I need, my monitor is a 25" OMEN 144hz 1080p.
Here's the current build:
Any incompatibilities I'm not aware of? Planning on adding some Chromax heatsink covers / fans to the Noctua cooler (in the future), and I'm probably going to use the H710 (instead of the H700) when it is released.
Thanks for any help!
Stormtrooper PC
CPU - Ryzen 3700x
Cooling - Noctua NH-D15 SE-AM4
Motherboard - Gigabyte X570 Gaming X
RAM - G.Skill Trident Z RGB DDR4-3600
GPU - Nvidia GeForce RTX 2070 Super
Storage - Samsung 970 EVO 500GB
PSU - Corsair RMx 550W
Case - NZXT H710
Display - HP Omen 25
https://linustechtips.com/topic/1096138-ryzen-3000-build/
I'd replace the RM650 for the RM550x since 550W is still sufficient for this build and the RM is significantly stripped down from the original RMx for the same price (even factoring in that 15$ rebate).
In fact if you want 650W I'd also favor the TX650M over the RM (2019), it's kinda of a bait and switch from Corsair use the "RM" branding on a power supply that is significantly inferior to the RMx we all know and love.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1096138-ryzen-3000-build/#findComment-12824996
Thanks for the advice, PSU naming schemes are a bit confusing.
Stormtrooper PC
CPU - Ryzen 3700x
Case - NZXT H710
https://linustechtips.com/topic/1096138-ryzen-3000-build/#findComment-12825021
Is there by any chance a buying guide for Corsair power supplies that tells which model lineups are good and which ones aren't so great?
https://linustechtips.com/topic/1096138-ryzen-3000-build/#findComment-12825058
I made my original decision on the PSU using the LTT PSU Tier List here:
Stormtrooper PC
CPU - Ryzen 3700x
Case - NZXT H710
https://linustechtips.com/topic/1096138-ryzen-3000-build/#findComment-12825073
Oh darn.
Another victim of the confusing placements of some of the Psu in ther tier list.
Even though jonnyguru himself has said that the RM 2019 is worse than the txm in builda quality.
https://linustechtips.com/topic/1096138-ryzen-3000-build/#findComment-12825091
2 minutes ago, hello_there_123 said:
Oh darn.
It's a good thing I posted here before buying then lol
Stormtrooper PC
CPU - Ryzen 3700x
Case - NZXT H710
https://linustechtips.com/topic/1096138-ryzen-3000-build/#findComment-12825112
PCPartPicker Part List
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor  ($499.00 @ B&H)
CPU Cooler: Scythe Mugen 5 Rev. B 51.17 CFM CPU Cooler  ($48.99 @ Amazon)
Motherboard: Asus TUF GAMING X570-PLUS ATX AM4 Motherboard  ($181.60 @ OutletPC)
Memory: Team T-FORCE VULCAN Z 32 GB (2 x 16 GB) DDR4-3200 Memory  ($146.99 @ Newegg)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive  ($94.89 @ OutletPC)
Video Card: MSI GeForce RTX 2070 8 GB GAMING Video Card  ($439.98 @ OutletPC)
Case: Antec Dark Fleet DF500 RGB ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: FSP Group Hydro GE 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($79.99 @ Amazon)
Total: $1551.43
Generated by PCPartPicker 2019-08-20 16:27 EDT-0400
https://linustechtips.com/topic/1096138-ryzen-3000-build/#findComment-12825190
Memory: OLOy WarHawk RGB 32 GB (2 x 16 GB) DDR4-3200 Memory  ($129.99 @ Newegg)
Video Card: Sapphire Radeon RX 5700 XT 8 GB PULSE Video Card  ($419.99 @ Amazon)
Case: Cooler Master MasterBox NR600 (w/o ODD) ATX Mid Tower Case  ($69.99 @ Amazon)
Power Supply: BitFenix Formula Gold 650 W 80+ Gold Certified ATX Power Supply  ($75.99 @ SuperBiiz)
Total: $1471.45
Generated by PCPartPicker 2019-08-21 00:21 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1096138-ryzen-3000-build/#findComment-12826142
What about something like this:
MSI B450 Tomahawk should be fine to run a 3900X and it has bios flashback so you can update the bios for Ryzen 3000 compatibility.
You can opt to go down in GPU to a 2070 vanilla and invest on a better case if you don't like the size or airflow of the H500.
https://linustechtips.com/topic/1096138-ryzen-3000-build/#findComment-12828029
3 hours ago, PuppyStomper said:
Is there a specific reason you want a x570 MB? If not, I'd look into a b450 with a USB firmware option. Msi is from what I understand a solid option.
I'm planning on taking advantage of pcie 4.0 down the road, and only X570 supports that right now
Stormtrooper PC
CPU - Ryzen 3700x
Case - NZXT H710
https://linustechtips.com/topic/1096138-ryzen-3000-build/#findComment-12828369
Planning on using an X570 board for pcie 4.0, but I could definitely tweak this build
Stormtrooper PC
CPU - Ryzen 3700x
Case - NZXT H710
https://linustechtips.com/topic/1096138-ryzen-3000-build/#findComment-12828375
Total: $1471.45
Why is everyone recommending the Intel SSD over Crucial? I thought Intel's had a bad rap?
Stormtrooper PC
CPU - Ryzen 3700x
Case - NZXT H710
https://linustechtips.com/topic/1096138-ryzen-3000-build/#findComment-12828395
