Hi, not sure if this was the correct place to post this but I have an old multimeter that had battery leak corrosion on the battery contacts. I today cleaned them with citric acid (based on recommendations online) and let dry and made sure it was all clean.
Now when I put batteries in it (after fully dry) and turn it on, I'm getting lots of random readings on multiple settings without any probes attached, even attached the inputs don't seem to remedy the situation. Only on ohms setting does this not happen. I'm not sure what is wrong as I'm not a big user of multimeters, this one is an old device from my late father and I remember it working fine before leaving batteries in it for a long time period.
Could there be ireversvable damage or could something else be wrong? it does have a fuse also. The make and model of the meter is a Soar ME-540 Digital Multimeter.
Thanks in advance for any help.
Wraith/Main Rig: AMD Ryzen 7 5800X3D | DeepCool AK620 | ASRock X570 Steel Legend | Micron Workstation ECC 64GB | XFX Speedster SWFT 319 Radeon RX 6800 XT 16GB | Topping D50s+A50s+PA3s | Seagate FireCuda 520 NVMe 500GB, Samsung 860 EVO M.2 1TB, Samsung 970 EVO Plus NVMe 2TB, HPE SSD 1.92TB, Toshiba X300 4TB, Seagate SkyHawk 4TB, WD Blue 4TB, HPE HDD 8TB | LG GGW-H20L Bluray-RW, Pioneer DVR-220LBK DVD-RW | HP NC550SFP 10GbE | Super Flower Leadex II Gold 750W | CoolerMaster MasterCase MC500P - Ghost/Test Rig: AMD Ryzen 7 1800X | Scythe Mugen 5 Rev.B | Asus ROG Strix X370-F | Crucial Ballistix Red 16GB | ASRock Intel ARC A770 Phantom Gaming D 8GB | Asus Xonar D2X | Crucial MX500 250GB, Seagate BarraCuda 500GB | SAMA Forza 750W Gold | Antec GX200
Phantom/Win98 Rig: AMD Athlon XP-M 2500+ | Arctic Cooling Copper Silent 3 | ASRock K7S41GX | Elixir 512MB | ATI Radeon 9800 XT 256MB with ATI Silencer 3 Rev.2 | Aureal BA88DL30A-01 Vortex 2 | Seagate Barracuda 160GB | LiteOn IHDP118-18 DVD-Rom | Samsung FDD | Ccivo 300W | CiT S008B - Parvati IV/Home Unraid Rig: Dual AMD Opteron 4184 | 2x Noctua NH-U12DO A3 | Supermicro Aplus H8DCL-i | Samsung ECC 32GB | Matrox G200eW 16MB | Kioxia Exceria G2 1TB, HPE Seagate Exos 4TB, 2x Seagate Barracuda Green 2TB, 2x Toshiba E300 2TB, Seagate SkyHawk 2TB, 2x Samsung Spinpoint F4EG 2TB, Seagate Essentials 1TB, WD Green 500GB | Dell Perc H200+H310 HBA, HP NC550SFP 10GbE | Cooler Master MWE v2 850W | Corsair Obsidian 750d Full Tower - Behemoth12/Second Unraid Rig: HP Microserver G8 | Xeon E3-1220L V2 | Intel C204 | Hynix ECC 16GB | Matrox G200eH 16MB | WD Green 500GB NVMe |
https://linustechtips.com/topic/1096137-multimeter-help/
9 minutes ago, YoFavRussian said:
Did you investigate further inside the meter, I've seen where corrosion will leak into areas and cause issues with traces on PCBs. That would call for a trace repair.
That I did not, so now I will. I'll report back later on what I find and probably take a picture.
https://linustechtips.com/topic/1096137-multimeter-help/#findComment-12825076
Based on your post, it's been sitting in the corrosion for awhile. So I would definitely recommend taking the plastic shell off and giving it a good scrub. And looking over the board pretty well should be pretty obvious if the corrosion has gotten into it.
https://linustechtips.com/topic/1096137-multimeter-help/#findComment-12825093
Are the batteries you put in brand new?
https://linustechtips.com/topic/1096137-multimeter-help/#findComment-12825113
So after taking it apart I see the corrosion went further along the same contacts that was hidden by the plastic so I cleaned those up. (although the cleaning left marks of its own) I couldn't see anymore damage or anything out of place but couldn't look under the board as its firmly in place and I didn't want to break it with unnecessary force.
Here's a link to some photos I took below, I'm still waiting on it to dry before trying it again.
https://imgur.com/a/8ahUjGP
https://linustechtips.com/topic/1096137-multimeter-help/#findComment-12825478
I used fully charged recharble AA batteries, not exactly new though.
https://linustechtips.com/topic/1096137-multimeter-help/#findComment-12825483
Try using alkalines.
https://linustechtips.com/topic/1096137-multimeter-help/#findComment-12825535
5 hours ago, Calidus said:
<snip>
Whats the other side of the board look like? see if you can pop it out, try removing the plastic knob on the front of the meter (carefully).
For future the fuse is 20mm, 200V, 200mA
Here is what I have been able to gather so far.
based on the ME-550, it looks like the only thing holding it together is the range selector knob.
Seeing as how close the batteries sit to the IC cutout (I labeled it wrong in the pic, not a uC) (see image below), there could be corrosion on the chip pins. The display could have also been affected by something. The traces are underneath, never hurts to take a look. There's a good possibility something 'shit the bed', leaky caps? dead chips? cooked resistors?, dirty pots?, hosed display?, lose wire?
https://linustechtips.com/topic/1096137-multimeter-help/#findComment-12825730
Okay, so yeah, there is a chance that the corrosion leaked even further to the other side of the board. I would recommend doing what everyone else has said to do. New batteries, Alkaline batteries do operate at a higher voltage compared to batteries like NiMH. And trying to remove that plastic knob and inspect the other side of the board. Leaving corrosion go is very bad as it will just continue to eat away at the traces and will eventually come back up to the battery terminal.
https://linustechtips.com/topic/1096137-multimeter-help/#findComment-12827192
So on the other side where the battery terminal goes through the board, there's some marks on the solder and terminal. So probably has gone through the one one behind the screen. No traces that I can see so far is damaged thankfully, I have however noticed a witish coating where I cleaned the previous terminals, seems citric acid may of not been a good idea. (although was suggested online as a cheaper alternative to the professional cleaners)
I think I may need to buy something that was actually made for the job before I continue further, does anyone have any recommendations on any products to clean the contacts and such?
https://linustechtips.com/topic/1096137-multimeter-help/#findComment-12831224
...well how bad was the corrosion? Citric acid is mainly used for dissolving rust (I had to look it up). I would shy away from using it on a pcb full strength. P.S. Acid and metal is not the best combo.
A better solution (Jacked from ifixit)
First remember that your batteries are alkaline not acidic. Alkalinity is just as corrosive as acidity but to clean it you will need the acidity. I use a 50/50 mix of vinegar and sterile water. It is okay to place the whole board in that solution. Use a small soft brush to gently scrub the residue of the board. Once it is properly cleaned, rinse it of with sterile water. Then clean the board with 90%+ isopropyl alcohol to displace all the water. Looking at the schematic, your GameBoy should work with just an AC adapter. If you post some images of your circuit board and the damage, I am sure we can give you a better idea on how to fix it.
I personally use distilled water followed by a good isopropyl rinse (for pcb cleaning in general).
I would get a wash bottle, and some anti-static brushes. Give your board a rinse down with the distilled water, agitate the surface of the pcb with your brush, rinse again, rinse with isopropyl, then let it dry (completely). This should help to remove any residual citric acid.
See what others have to say, I'm just one cowboy *pew pew*
https://linustechtips.com/topic/1096137-multimeter-help/#findComment-12831651
  Reveal hidden contents
Yeah, I think I made the mistake of using pure citric acid without diluting, I'm going to grab some distilled water and some ESD brushes off amazon and do a proper clean when I have the time. (works been busy)
I'll add a reply once I've taken another go at it, might be next week though.
https://linustechtips.com/topic/1096137-multimeter-help/#findComment-12847488
