Water spilled on k95 rgb. the q switch acts wierd
13 hours ago, DarthSmartt said:I spilled roughly half a glass water on my k95 with speed switches last night. i kept using it for a bit as it seemed to still be fine. about an hour later the q 1 and alt keys became spotty. I unplugged it and drenched it with rubbing alcohol. it has been about 18hrs since then. Everything works perfectly right now however i notice that when i press on the q key sometimes it repeats itself 3-4 times very briefly and on occasion doesnt do anything at all. I also did notice that the ertyui escape and windows keys start to flicker when i set them to purple. they wont go to purple. only shades of pink. and the blues look more green on those keys as well as caps lock tab and shift and this thing ~. The tab key looks dim as well. Will this possibly fix itself if it is dried out longer. I cant really take apart the keyboard as it's adhered together.
Oh man you shanked it good. I would place it outside and let the sun dry things up and if still the Q key gives issues then your sorta out of luck IMO ..I wonder if RMA covers water spillage, because they will know Im sure.
