For some reason all of a sudden my internet is really slow... anyone know why?3273846464.png
https://linustechtips.com/topic/109520-slow-internet-help/
Are you wired or wireless?
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/109520-slow-internet-help/#findComment-1463734
Wired and it is all devices in our house. Roku, all computers
https://linustechtips.com/topic/109520-slow-internet-help/#findComment-1463742
lol wat how do you load a webpage?
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
https://linustechtips.com/topic/109520-slow-internet-help/#findComment-1463744
For once a person has slower internet than me.
Call up you ISP ask for a better connection, I'm sure your entitled to faster net.
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/109520-slow-internet-help/#findComment-1463748
Well not usually
https://linustechtips.com/topic/109520-slow-internet-help/#findComment-1463752
Well not usually
Your ping is insanely high, are you in a rural or urban area?
https://linustechtips.com/topic/109520-slow-internet-help/#findComment-1463760
restart the modem and router?
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/109520-slow-internet-help/#findComment-1463772
Suburbs. It isn't usually like this
https://linustechtips.com/topic/109520-slow-internet-help/#findComment-1463789
Did multiple times.
https://linustechtips.com/topic/109520-slow-internet-help/#findComment-1463791
Again, I'd call you ISP, they should be able to do something.
https://linustechtips.com/topic/109520-slow-internet-help/#findComment-1463792
We are currently doing that so it should be fixed if they can fix it
https://linustechtips.com/topic/109520-slow-internet-help/#findComment-1463800
I'm pretty sure they will be able to, if not than they might give you a better plan as that seems to be the case if they can't.
https://linustechtips.com/topic/109520-slow-internet-help/#findComment-1463820
:o your ping is lengendary :o
Are your neighbours having the same problem?
A low ping is good right? And I'm not sure if they are, my neighbors are all old.
https://linustechtips.com/topic/109520-slow-internet-help/#findComment-1464258
  • 4 weeks later...
yea. (my ping is 30ish usually) your ping shouldnt be that high,that's way too high. Check your phones/phone lines, you may have something thats going to ground. (i had that problem with an old phoneline when we were remodelling a room) Has your ISP rectified the problem as yet?
sorry about taking so long to reply, i've been away for awhile
https://linustechtips.com/topic/109520-slow-internet-help/#findComment-1600165
