FX-8320 Overclock settings
By
FreezeFlyte
in Troubleshooting
in Troubleshooting
Solved by Flyguygamer,
You have some room for a voltage bump. Just try for anywhere between 4 and 4.8 GHz and add voltage as needed. I would try for 4.5 Ghz at 1.35 volts and check your temps. Don't go over 65 degrees on prime95
Ryanwake ·
Posted in General Discussion1 -
Greasy_Pudding ·
Posted in Servers, NAS, and Home Lab0 -
1
thrasher_565 ·
Posted in Hot Deals0 -
5
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
9
derekchan ·
Posted in New Builds and Planning15 -
1
play_circle_filled
Latest From ShortCircuit:
