Parts list:
Ryzen 5 3400G
MSI B450 Tomahawk Max (a bit overkill...)
Patriot Viper 16Gb dual Channel 3200Mhz
500GB Crucial P1 M.2 NVMe SSD
Cooler Master MWE 550W 80+ bronze
Aerocool Cylon
AOC M2060SWD
Redragon Anala
Update:
+ 5 120mm Cryorig QF120 Performance
https://linustechtips.com/topic/1095037-first-build/
Good stuff man! Can you change the color on the front of your case? I haven't seen that one before but I do like it, just would be nice if it had that customization.
Happy gaming!
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
https://linustechtips.com/topic/1095037-first-build/#findComment-12815844
Happy gaming!
The case is an Aerocool Cylon and it has 13 lighting modes for the front panel RGB
https://linustechtips.com/topic/1095037-first-build/#findComment-12816886
