Im sorry if this post is in the wrong spot, but didnt know where to post this.
Recently I have had some problems with my power going out, and have lost a power supply so far cause of it. So I need a UPS.
Can you guys suggest a UPS for my system.
My specs are..
Intel I5-3570k @ 4.2
Asus Maximus V Formula
Corsair H100I
Corsair AX860I
Samsung 840 120g ssd
WD 1tb HD
2 EVGA gtx 770 sc in sli
16gb of Corsair dominator platinum @ 1866
Asus Xonar Essense STX
and an optical drive
monitor- Asus VG248QE
Edit: forgot a few things.
https://linustechtips.com/topic/109497-need-help-choosing-a-ups/
I too would be interested.
A family member got one similar to this: http://www.amazon.co.uk/APC-BE700G-UK-Interface-Power-Saving-Back-UPS/dp/B002RXED6A/ref=sr_1_1?ie=UTF8&qid=1391213065&sr=8-1&keywords=UPS
He uses it on an old Dell i7 860 system. That tower, monitor, router, printer plugged into it. It lasts about 10-20 minutes on backup, enough to save what you are doing and shutdown safely. :)
https://linustechtips.com/topic/109497-need-help-choosing-a-ups/#findComment-1463431
The Cyberpower 1350 is a solid piece of equipment. http://www.amazon.com/CyberPower-CP1350AVRLCD-Intelligent-Series-Mini-Tower/dp/B000OFXKFI/ref=sr_1_1?ie=UTF8&qid=1391213350&sr=8-1&keywords=Cyberpower+1350.
Three year warranty, well built. Software could be better but is perfectly functional. Rated for 810 Watts which about matches your PSU so should be plenty. They have variants for different loads you can select on that page.
Case: Meatbag, humanoid - APU: Human Brain version 1.53 (stock clock) - Storage: 100TB SND (Squishy Neuron Drive) - PSU: a combined 500W of Mitochondrial cells - Optical Drives: 2 Oculi, with corrective lenses.
https://linustechtips.com/topic/109497-need-help-choosing-a-ups/#findComment-1463445
That looks great! right around my price range aswell.
Now would this be able to handle another monitor in the future? maybe a 27 inch 1440 in adition to what I have?
https://linustechtips.com/topic/109497-need-help-choosing-a-ups/#findComment-1463459
Anything APC will do the trick quite well. They have stats on their website as to how long a unit will last on its battery.
Yeah to be on the serious side, I typically use APC for my surge protect power bars and UPS. I like them and have never had an issue.
https://linustechtips.com/topic/109497-need-help-choosing-a-ups/#findComment-1464563
