FPS drops to single digits despite stable system, good temps, and good hardware
3 hours ago, Zach04.07 said:I have the same problem they always answer check temps even though I clearly stated I checked temps
On 8/17/2019 at 2:17 AM, Cigano said:I literally have no idea what could be causing this, any ideas
But did you check your temps? Just kidding, ok lets think what that may be.
Check task manager if there is any processes running in background, they may cause this type of issues. Open msi afterburner, it have nice graph what’s going on with the system, once this type of issue occurs check it straight away to see behaviour of gpu and cpu, if there is any dips in utilisation or maybe something hits cpu really hard when that happens.
I had similar problem with my previous system, it was windows security something something which was hitting cpu every few minutes quite hard.
