1 minute ago, AndrewTaylor1999 said:
Could I get away w/ changing the 960 gb to a cheaper 500? I dont' really know how much memory I need, I only play like 4 of 5 games.
https://linustechtips.com/topic/1094854-first-final-build-help/#findComment-12814423
Starting with less space now and adding more is a good move, since it's super easy to toss a new hard drive in later.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1094854-first-final-build-help/#findComment-12814452
How does a X900 sound? https://pcpartpicker.com/product/7stQzy/hp-ex900-500mb-m2-2280-solid-state-drive-2yy44aaabc
https://linustechtips.com/topic/1094854-first-final-build-help/#findComment-12814461
15 minutes ago, AndrewTaylor1999 said:
would work decently
Primary PC:
PSU tier list
https://linustechtips.com/topic/1094854-first-final-build-help/#findComment-12814485
9 minutes ago, AndrewTaylor1999 said:
Do you see anything else on this build I could improve / minimize for price?
Unless you really want fully modular, @hello_there_123 recommended a very solid unit. A used graphics card goes a long way too (I'll actually be selling a 580 8GB soon myself). Otherwise very solid choices
Primary PC:
PSU tier list
https://linustechtips.com/topic/1094854-first-final-build-help/#findComment-12814525
Thank you! Do you happen to know about the Ryzen 3000 BIOS update? I know the B405M gaming pro does have BIOs Flashback, however I have absolutely NO idea how to do the bios update. However, I know the Tomahawk comes with the 3000 update already on it, but it's also around $30 more expensive. I don't really see any other difference between the two motherboards, do you think it would be worth just getting rid of the hassle or is there really no hassle at all to upgrade?
https://linustechtips.com/topic/1094854-first-final-build-help/#findComment-12814565
You go to the webpage for the motherboard on msi's website, and then you download the BIOS file onto a USB stick, and then it should be as easy as putting the memory stick into the USB port that's labeled on the back and pressing the BIOS flash button. There are loads of helpful YouTube tutorials for this so feel free to peruse them.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1094854-first-final-build-help/#findComment-12814569
you can cut off a few bucks by getting a B450M/AC, has wifi and doesn't require a BIOS update.
https://linustechtips.com/topic/1094854-first-final-build-help/#findComment-12814640
I'll recommend something like this...
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  ($133.00 @ Amazon)
Motherboard: ASRock B450M/AC Micro ATX AM4 Motherboard  ($74.99 @ Amazon)
Memory: Team T-Force Vulcan 16 GB (2 x 8 GB) DDR4-3200 Memory  ($65.99 @ Newegg)
Storage: HP EX900 500 GB M.2-2280 NVME Solid State Drive  ($49.99 @ Amazon)
Video Card: Sapphire Radeon RX 580 8 GB PULSE Video Card  ($169.99 @ Newegg)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  ($44.99 @ B&H)
Power Supply: BitFenix Formula Gold 650 W 80+ Gold Certified ATX Power Supply  ($75.99 @ SuperBiiz)
Monitor: AOC C24G1 24.0" 1920x1080 144 Hz Monitor  ($161.99 @ Amazon)
Total: $776.93
Generated by PCPartPicker 2019-08-16 22:47 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1094854-first-final-build-help/#findComment-12814679
