On 8/18/2019 at 4:28 AM, zrmaxwell said:
Marshall MID ANC will sound bad when compared to the Sennheiser Momentum On Ear.. Mostly due to the Active Noise Cancelling circuitry taking up valuable space inside such a small ear cup, which leaves little room for acoustics.  Personally i would recommend a better pair of passive noise isolating headphones. So, if you are willing to look at other headphone options i would be more than happy to tell you some..
Other headphone on my list is Sony WF-1000XM3
On 8/21/2019 at 5:49 AM, zrmaxwell said:
Add the Sony MDR-1000X Mark 3 Active Noise Cancelling Wireless headphones & the Audio Technica ATH M50x BT (Only for their 38-40 hour battery life) to your list of headphones to look at...
Okay , thanks mate , will add that to my list
