I want a little advice about my system. I have chosen the following parts and as you can see I haven't chosen a case neither the cooling system. The reason is that I want to make it as silent and as cool as I can.
As for the budget, I'd like to spend something between 100-150 and for the cooling system I'd like to spend maximum 60% of the case's budget.
Do you have any suggestions for a silent PC case and cooling system?
Parts picked
https://linustechtips.com/topic/1094701-ryzen-9-silent-build/
PCPartPicker Part List
Type Item Price
CPU Cooler be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler $89.90 @ Amazon
Case Fractal Design Meshify C ATX Mid Tower Case $89.99 @ Walmart
Case Fan be quiet! SilentWings 3 PWM 50.5 CFM 120 mm Fan $24.49 @ SuperBiiz
  Prices include shipping, taxes, rebates, and discounts
  Total $204.38
  Generated by PCPartPicker 2019-08-16 10:27 EDT-0400
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1094701-ryzen-9-silent-build/#findComment-12812949
The Meshify isn't actually so great as it lacks the sound dampening on the side panels that the Define C has.
Also 200$ for 16GB RAM is just stupid
Quote and/or tag people using @ otherwise they don't get notified of your response!
The HUMBLE Computer:
AMD Ryzen 7 3700X • Noctua NH-U12A • ASUS STRIX X570-F • Corsair Vengeance LPX 32GB (2x16GB) DDR4 3200MHz CL16 • GIGABYTE Nvidia GTX1080 G1 • FRACTAL DESIGN Define C w/ blue Meshify C front • Corsair RM750x (2018) • OS: Kingston KC2000 1TB GAMES: Intel 660p 1TB DATA: Seagate Desktop 2TB • Acer Predator X34P 34" 3440x1440p 120 Hz IPS curved Ultrawide • Corsair STRAFE RGB Cherry MX Brown • Logitech G502 HERO / Logitech MX Master 3
Notebook:  HP Spectre x360 13" late 2018
Core i7 8550U • 16GB DDR3 RAM • 512GB NVMe SSD • 13" 1920x1080p 120 Hz IPS touchscreen • dual Thunderbolt 3
https://linustechtips.com/topic/1094701-ryzen-9-silent-build/#findComment-12812977
I'm not from USA and that ram (the one I chose) is about 100 euros and as for the case I'd like to know your opinion on the ones that be quiet! offers vs the one that you suggested.
https://linustechtips.com/topic/1094701-ryzen-9-silent-build/#findComment-12813008
For high performance quiet cooling your options are either a Dark Rock Pro 4 or Noctua NH-D15.
Also if you want quiet get a triple slot triple fan GPU. You can get the quietest CPU cooler in the world but it won't make a bit of difference if your GPU is revving away like an engine.
https://linustechtips.com/topic/1094701-ryzen-9-silent-build/#findComment-12813036
I see, I couldn't tell where you'Re from since your post doesn't follow the suggested guidelines:
I have no experience with be quiet! cases, but I like my Define C very much. The only thing that's "bad" about it is if you have a non-modular PSU, the cables are kinda hard to stuff away, and you won't be putting a ton of hard drives in it.
In the top right corner you can change the location PCPartPicker is set to. For EU Germany is generally the one where prices are closest to real life.
https://linustechtips.com/topic/1094701-ryzen-9-silent-build/#findComment-12813048
I will have that in mind, because before, I was between RTX 2080 ti windforce and the one that I showed you. Either way, thank you for your advice
https://linustechtips.com/topic/1094701-ryzen-9-silent-build/#findComment-12813221
I'm sorry for the confusion, I am going for the one that is full modular. Specifically, I'm going for "EVGA SuperNOVA 750 G1+"
https://linustechtips.com/topic/1094701-ryzen-9-silent-build/#findComment-12813253
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor  ($499.00 @ B&H)
CPU Cooler: Scythe Mugen 5 Rev. B 51.17 CFM CPU Cooler  ($48.99 @ Amazon)
Motherboard: ASRock X570 Phantom Gaming X ATX AM4 Motherboard  ($338.89 @ OutletPC)
Memory: G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-3600 Memory  ($99.99 @ Newegg)
Storage: Intel 660p Series 512 GB M.2-2280 NVME Solid State Drive  ($59.99 @ Amazon)
Video Card: EVGA GeForce RTX 2080 Ti 11 GB Black Video Card  ($1052.99 @ SuperBiiz)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Amazon)
Power Supply: EVGA SuperNOVA G1+ 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($85.88 @ OutletPC)
Total: $2285.72
Generated by PCPartPicker 2019-08-16 13:25 EDT-0400
https://linustechtips.com/topic/1094701-ryzen-9-silent-build/#findComment-12813488
